Southern California Area Southern California Members.
temperature sensor switch
Old Oct 18, 2010 | 02:30 AM
chevyridaz's Avatar
Car: 89 droptop
Engine: 5.0 tpi
Axle/Gears: stock rear end
Where is it located in a/my 89 camaro 5.0? and what does it do??? I want my fans to turn on at a lower temperature,
Old Oct 19, 2010 | 12:16 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: temperature sensor switch
The fan temperature switch is located on the passenger side of the engine, between the #6 and #8 cylinders. Because of its location near the exhaust manifolds, expect the connector to crumble in your hands when you remove it. Be prepared to cut and solder in a new connector at the same time.
The stock fan switch comes on around 225*-230*. You can get a new stock one for an '86-'87 Buick Grand National that comes on around 205*. Or you can get an aftermarket one that comes on around 185*.
I would also recommend a lower temp thermostat as well, when you install the new fan switch. The stock thermostat is 195*, and if you install a lower temp fan switch, the fan will be running all the time.
Old Oct 20, 2010 | 06:45 AM
chevyridaz's Avatar
Car: 89 droptop
Engine: 5.0 tpi
Thanks for very helpful info man. What about a 160* thermostat?
Old Oct 21, 2010 | 11:04 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Too cold, stick with a 180
Unfortunatly the local supplier of the 180 fan switch can no longer get them.
So the best bet is the GN one.
Old Oct 23, 2010 | 03:21 AM
mikespeed's Avatar
Car: 87 IROC
I have a Hypertech 4028 (on at 200* off at 185*) fan switch and a 180* t-stat and once the car warms up the fan does not go off. Don and Kevin know a lot more than I do but I'm pretty sure the switch in the cylinder head only activate one of the cooling fans.
On the other hand,... the temp hasn't gone up to 220* since I installed them. It got close once, but I was charging some serious hills and it was over 100* that day.
P.S. In hindsight I would have taken the grand national switch. If I'm not mistaken its about 1/3 the price of the hypertech. You should be able to get it at any parts store. FYI: If the counter guy at the parts store can't find the switch in the computer tell him to look under air conditioning. I have no idea why air conditoning, but it took almost 45 min at CSK for the counter guy to figure it out. Maybe it will save you some time.
Old Oct 29, 2010 | 07:14 AM
chevyridaz's Avatar
Car: 89 droptop
Engine: 5.0 tpi
thanks guys for your advice, i drained the coolant so far and looking into that gn switch...
Old Oct 29, 2010 | 09:43 AM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Originally Posted by chevyridaz
... I want my fans to turn on at a lower temperature,
Have you considered the Derale fan controllers? They enable manually setting the temperatures to a wide range, providing cooler temps for hot weather and dialing in hotter temps for passing smog.
http://www.derale.com/basic/default.aspx
Does anyone have hands-on experience with these?
Old Oct 29, 2010 | 01:43 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
That sounds like a good idea if it works.
Am I missing something, can't find prices or where to buy on their site
Old Oct 29, 2010 | 05:35 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
You can go to Summit racing or Jegs to get one. As for smog, Just disconnect the relay to the main fan while the car is being smog.
Old Nov 12, 2010 | 06:43 AM
chevyridaz's Avatar
Car: 89 droptop
Engine: 5.0 tpi
So my car is equipped with dual fans, as many other fbodys, i noticed only one fan comes on at around 230* as mentioned by mikespeed. what gives?
Old Nov 12, 2010 | 09:32 AM
Duck's Avatar
Engine: 5.7
Making the engine run even hotter than normal to reduce emissions is a tactic that makes a lot of sense to me. I've been considering bypassing the OEM fan sensors and relays on both my TPI with two fans, and my TBI with one fan, by using the external Derale temperature sensor and a separate wiring harness directly to the battery. This would enable regulating when the fans turn on and off independently from the computer, while still allowing the computer to change fuel-air ratios according to the engine temp. Personally, I've never liked the way the dual fans work or even the fans themselves, as they're not well designed. Any thoughts on this?
Old Nov 12, 2010 | 03:16 PM
Kevin91Z's Avatar
Which fan? Driver's side or passenger side?
Old Nov 12, 2010 | 09:04 PM
chevyridaz's Avatar
Car: 89 droptop
Engine: 5.0 tpi
drivers side comes on, passengers side stays off. is that normal? or do they turn on at different temps?
Old Nov 12, 2010 | 10:31 PM
mikespeed's Avatar
Car: 87 IROC
Well, heres what you need to do.
Get the front end of the car off the ground slide under and find the fan switch in the cylinder head on the passenger side.
Take the plug off of the switch; with a paperclip ground the wire to the block. (Make sure the engine is off, but have the key in the on position.) If nothing happens the fan may be bad.
If the fan comes on, the switch is bad.
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
soarestransam
Aug 24, 2015 08:15 AM
92camaroJoe
Aug 13, 2015 06:07 AM
