Southern California Area Southern California Members.
Super ram intake
Old 09-25-2011, 07:53 PM
niGhTcrAwler1's Avatar
Super ram intake
What do u guys think about it? Feedback please. What's the average price for one? I'm about to purchase one and don't know much about them.
Old 09-26-2011, 10:29 AM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
Re: Super ram intake
Looks nice once its installed, and you hope you just have to install it once
Old 09-26-2011, 01:08 PM
Didn't answer anything for me.
Old 09-26-2011, 01:09 PM
Guest
Guest
Posts: n/a
yeah and you better know how to adjust the valves and rockers. The small screws you can notch them for a flat screw driver and that makes it easier for the Super Ram plenum bolts to be put in. You want to get the resin gasket glue for the gaskets you want to put them on the runners of the super ram. Now Im not sure hp wise but I think they give a stock 350 30-40 hp. And close to 50- 55 hp tuned and using a 1000 cfm throttle body.
Old 09-26-2011, 01:45 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
yeah I wouldn't bother spending the money on one if this is for a stock motor, or anything close to stock. I would think you would be much better for with some aftermarket runners and perhaps a better intake and ported plenum.
I did use the TPIS intake manifold rather than the Accel one when I bought mine, as far as average price that depends on how you want to put it together.
52 or 58mm throttle body
Intake Manifold?
New or Used?
Old 09-26-2011, 03:28 PM
Guest
Guest
Posts: n/a
I think a set of 1 3/4 headers would be better. How ever in a since if your building a Super Ram full set up on a stock 350 it's just to much for the total cost.
Old 09-26-2011, 08:45 PM
Parrydise7's Avatar
Car: 1985 Camaro
Engine: .040" over 350
Axle/Gears: 9-bolt with 3.45s
I'm afraid I have to disagree. That response told you everything you needed to know.
Old 09-26-2011, 09:36 PM
Thanks for the feed bad guys. I'm installing it in my 90 GTA LT headman headers, pulley, and shift kit with 373's. Just looking for a bit more power out of it. I'm thinking about going the ls1 route but I know it's a hasle
Old 09-27-2011, 10:19 AM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
My opinion is without the need for more fuel, meaning an engine with more compression/modifications the air you are going to add with the SuperRam is probably going to kill some of your low end torque, granted with your gears it will probably not "feel" so bad and you will likely achieve a high total MPH. Having already gone that route with a thirdgen and if I had the opinion of staying with an L98 or waiting and saving and going through the "hassle" of an LS1 swap I would honestly go with the swap. One major reason being the tunning difference plus the overall driviability once you are done.
Old 09-27-2011, 10:20 AM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Old 09-27-2011, 05:33 PM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
what i have read on these lingenfelter intakes is that they are better suited for stroker engines and best for 383 and they are APITA to install i have also read that the FIRST TPI intake is justas good as the superram but maintains a stock look but more hp gain some people dont like the superram because they say it looks like a transmission pan but i like it well thats just my
Old 09-27-2011, 07:47 PM
Guest
Guest
Posts: n/a
No they all dont look like transmission pans. My super ram is chromed and polished honed an polished. I have installed the Sr at one time with my stock tuned 350. I did notice that I gained a feel of Hp gained. The top end was well noticeable. If you do every thing I mentioned with the Super Ram, It can be installed in 1 hour with the valves adjusted and thats with one experience person and I say a Novice. The super ram does have the perfect match with a stroker. The stroker needs air and the Sr gives it almost all it needs. Of course I have the flow of the heads and the headers.
Building a Tpi Vs an Ls1 is yes the Ls1 abiltys are greater. But I much rather go for the Tpi over all being what you can build for the dollar with the tpi over the ls1. Tuning for the Ls1 is more advanced yes, but you can still get stuck into a tune that just may not work well and you may never be able to get it corrected unless you hire a professional. With Tpi your most likely going to get someone with the experiece and hopefully equipment to tune overall the equipment is probably cheaper.
Old 09-28-2011, 02:16 AM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Everything but the first sentence, is the exact opposite. Save your pennies for that swap. Its a long road, but once its in there, you'll be smiling ear to ear for years to come.
Old 10-01-2011, 12:59 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
It only told him something if he had knowledge about the SuperRam in the first place. Its like an inside joke and he didnt understand.
The SuperRam is a difficult to install intake manifold system, but it works better than the stock intake, for sure. To really make it flow better, you can siamese the runners so its one big runner feeding two cylinders.
Old 10-01-2011, 08:26 PM
Guest
Guest
Posts: n/a
If you do that what you gain an loose tq? Im for the top end range of things just like an end of a 1/4 you want to push it even more. I think thats why I had some .500 reaction times with the torque. I gotta have the torque for you manuals out the hole.
Old 10-09-2011, 10:27 AM
Parrydise7's Avatar
Car: 1985 Camaro
[QUOTE=Kevin91Z;5055146]It only told him something if he had knowledge about the SuperRam in the first place. Its like an inside joke and he didnt understand.
Agreed, but where I come from, particularly when you don't know anything about the subject, a response like that is considered rude.
Hotrodboba400
12-10-2019 07:07 PM
db057
04-28-2019 07:45 AM
Stangski09
11-14-2015 01:27 PM
Formula_88AE
09-03-2015 01:47 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Super ram intake
