Southern California Area Southern California Members.
Check Engine Light
Old Jun 12, 2012 | 12:00 AM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
Check Engine Light
i have a check engine light but whant to see if my fellow so cal thirdgeners can help me out...
car has a check engine light pulled the code it is code 23 mat sensor i used a flow chart to diagnose as best of my ability but changed the ecm nothing changed the mat sensor nothing still comes on and at this rate it will never pass smog and run how its supposed to mechanically and emission wise also noticed that the fans dont turn on either so im all ears to diagnose this if it does not work will take it back to dyno don and let him work his magic wich is my last resort
Old Jun 14, 2012 | 10:45 PM
captain_camaro's Avatar
Car: 1989 camaro Rs or iroc clone??
Engine: 5.oh tpi
Transmission: borg warner t5 world class
Axle/Gears: 3.23-GU5
Re: Check Engine Light
check the IAT?
maybe a bad ground..check the wiring on the firewall/heads the grounds might be loose?
just my 2cents..
Old Jun 14, 2012 | 11:50 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Use this:
http://www.gearhead-efi.com/gearhead...c/TPIcodes.pdf
If there is a problem, it WILL be located here. I had a code 42 that indicated a faulty ignition module/ecm, I had the module tested twice and both times it turned out fine. The problem ended up being a shorted wire that runs to the module.
Old Jun 15, 2012 | 12:39 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you changed the sensor and the code remains, then there must be a short or open in the wires to the sensor.
Old Jun 16, 2012 | 01:57 AM
DiabloWS6's Avatar
Originally Posted by captain_camaro
check the IAT?
just my 2cents..
i will check the wiring completly hope fully i find the problem so it can get smogged soon i will also check the firewall/heads ground for good contact
Old Jun 16, 2012 | 02:32 AM
DiabloWS6's Avatar
Originally Posted by kkingsrulee
Use this:
thanks for the link looks like a lot of usefull info i will use it to the best of my ability i hope its something small
Old Jun 16, 2012 | 02:33 AM
DiabloWS6's Avatar
i think its gona be short or a wire got kinked to much and its almost cut or not making contact any more
Old Jun 22, 2012 | 02:39 PM
DiabloWS6's Avatar
ok this is wierd i made sure that the wires were good behind the block the ground i took the car for a drive around the block surpisingly it did not turn the check engine light on as it would normally do it lasted a good while but pulling back into the garage it started to head up the fans did not come on because i could not hear them running and then the check engine light came on could this be setting off the code:23 for the mat sensor i think it has something to do with it
Old Jun 27, 2012 | 11:30 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Can you drive it over Thursday or Friday?
Old Jun 27, 2012 | 04:51 PM
DiabloWS6's Avatar
yeah I'll take it tommorow
Old Jul 20, 2012 | 02:58 PM
Anteak's Avatar
Car: 85 T/A
Transmission: 700R Auto
Did you ever find out what the problem was?
I'm all ears...
Old Jul 20, 2012 | 03:06 PM
DiabloWS6's Avatar
no i still cant figure it out i had a miss hap with my 1LE brakes and could not make it to dyno dons shop he was going to look at the car and figure what the problem is
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
