Southern California Area Southern California Members.
two vacuum lines in wire loom coming from firewall
Old Jan 27, 2013 | 10:59 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I had a small meltdown under the hood and burned these two vacuum lines on my 89 GTA TPI car now I'm trying to figure out where they go?
Do I just hook them both up to vacuum?
I think one of them is for the HVAC control, not sure about the other one?
Old Jan 28, 2013 | 12:08 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: two vacuum lines in wire loom coming from firewall
Hvac and cruise ?
Size:  33.4 KBName:  3-78_zps53d519d6.gif
Old Jan 28, 2013 | 01:07 AM
Car: 89 GTA
Axle/Gears: 4.10
Cool, I'll just figure out which one is for HVAC and cap the other since I deleted my cruise!
Old Jan 28, 2013 | 01:11 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Two plastic hard lines should be only for hvac and heater control valve. Cruise control should be a rubber vacuum hose .
Old Jan 28, 2013 | 01:27 AM
Engine: Lb9
Transmission: M20
Was the fire caused bye the cyberdyne fuel sender ?
Old Jan 28, 2013 | 10:07 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The one that is in #4 retainer is the cruise
The #26 goes to the HVAC
The other is the heater control valve.
Old Jan 28, 2013 | 02:23 PM
Car: 89 GTA
Axle/Gears: 4.10
Do I hook up vacuum to both the HVAC and heater control valve lines then?
Old Jan 28, 2013 | 06:19 PM
Dyno Don's Avatar
No, the vacuum goes inside the to control valve and comes back out to open the heater valve.
theshackle
Mar 5, 2017 06:37 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
apie2546
Aug 10, 2015 05:43 PM
