Southern California Area Southern California Members.
Failed smog today
Old Feb 19, 2013 | 04:34 PM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
Failed smog today
I am outputting too much nox, apparently. the, max/610 measured/936 at 15mph and max/498 measured/794. Any ideas about how to tackle this? I have 10 days to fix it or I can't drive the car anymore.
Old Feb 19, 2013 | 07:17 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: Failed smog today
Why do have a time table to fix it? I've failed in the past, but never had a time table to fix it. I know people that have taken months to fix it.
Old Feb 19, 2013 | 07:44 PM
actarnoff's Avatar
Engine: 355 TPI
I didn't think they would send me my registration sticker if it didn't pass.
Old Feb 19, 2013 | 07:51 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Do what I did, replace the cats and make sure the timing is set at 6 degrees.
Old Feb 19, 2013 | 07:54 PM
actarnoff's Avatar
Engine: 355 TPI
The guy I take it to checks timing.
Old Feb 19, 2013 | 07:58 PM
Mikos_89's Avatar
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
High nox means you're running too lean. Combustion temps are too high. Could be bad O2 sensor, plugged EGR, vacuum leaks, carboned up pistons, low fuel pressure, retarded ignition timing, timing chain slipped a tooth (highly unlikely though), ect. Go through it and check those things.
Could also be a plugged convertor. Is it original? How many miles on it?
You can check it by looking at the exhaust maniofolds while the car is idling. They usually get real hot (sometimes glow red) if the convertor was plugged up.
Old Feb 19, 2013 | 08:43 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Now we know what failed, come by and I will show you how to fix the NOX. On your TBI.
What were the other #'s
Old Feb 19, 2013 | 08:48 PM
Dyno Don's Avatar
Check his ID (TBI)
Old Feb 20, 2013 | 10:00 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
If you drive with expires registration they will give you a fix it ticket $10. Unless it's more than 2 or 3 months late they usually wont's stop you. They could impound it but never heard of anyone's car being impounded for a late registration on the first time being pulled over. You can pay the fees before it expires and smog it latter without paying late penalties.
Old Feb 22, 2013 | 02:17 PM
67camarorsss's Avatar
Car: 89 RS
Engine: 305TBI (LO3)
Axle/Gears: IDK, 2.73?
When my 89 failed it turned out to be a malfunctioning EGR. I replaced it and all was good. And this was on an LO3 with almost a quarter million miles on it (sold it at 225,xxx).
Old Feb 24, 2013 | 09:09 PM
actarnoff's Avatar
Engine: 355 TPI
Welp, here's an update. I did the diagnostic tests as per the service manual, and found that the NAPA egr valve that was on there didn't hold any vacuum. It was a total dud. I replaced it with a delco unit. The one thing that I don't understand is, if the EGR valve didn't work, why didn't it throw a code? It was the constant popping up of a code 32 that prompted me to replace the EGR several years ago.
Anyway, going to retest tomorrow.
Old Feb 26, 2013 | 12:09 AM
actarnoff's Avatar
Engine: 355 TPI
Did a pretest today; with the new egr it's still 160 nox ppm over passing. I'm not sure what I'm going to do now.
Old Feb 26, 2013 | 01:30 AM
Mikos_89's Avatar
Engine: L98, LFX.
Axle/Gears: 3.27's.
Bring it down to Don's shop I guess.
Old Feb 26, 2013 | 03:02 PM
Jeffs82TA's Avatar
I think on tbi cars egress is normally open so vacuum closes it not opens it. Test your egr solenoid. Also set timing to zero degrees and spray Carb cleaner in ALL egr passagess.
Old Feb 26, 2013 | 09:06 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
NOx isnt related to the cat, is it? I remember the last time I failed it was because of the cat, but I dont remember if it was NOx or HC that it affects
timbuck
Convertibles
Sep 28, 2015 12:31 PM
wstephan96
Sep 25, 2015 04:28 PM
6998poncho
Sep 25, 2015 02:56 PM
