LS1 Gas Tank & Passing Smog
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
As some of you may know, the ls1 tank has an internal charcoal canister and an evap system that is essentially uncharted waters as far as making it work with the thirdgens. How does this work when attempting to pass smog? Any advice on what I need to do to get an ls1 gas tank set up smog legal would be much appreciated. Thanks for reading!
-Ian
-Ian
1 Post
Car: Iroc-Z
Engine: 383ci
Transmission: 700hp 700r4
Axle/Gears: 3:45
Re: LS1 Gas Tank & Passing Smog
-Ian
-Ian
the actual tank is legal on any motor. The ls3 charcoal canister and is the same as well so a ls1 tank would be no problem. if your simply looking to run the ls tank hook it just like factory and you will be fine.
Engine: 305 LB9
I mean, I have the tank in the car, I just have to run the vacuum tube from the plenum to the tank's charcoal canister?
AkDrifted
08-17-2015 07:45 PM
