Southern California Area Southern California Members.
Code 42
Old Jan 12, 2002 | 10:10 PM
89 TA's Avatar
Car: Trans Am/Kenworth
Engine: 383/435 Cat
Transmission: T5/10 speed
Code 42
Has anyone ever had a problem with code 42? I think I'm going to need a new computer.
Old Jan 14, 2002 | 02:03 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Code 42 is the ESC module. You could have a problem with it, the knock sensor, or the wiring between them and the computer. The ESC module is the square box on the firewall on the driver's side, and the knock sensor is on the passenger side bottom of the block. Dont confuse it with the fan switch, which is above it in the head.
Old Jan 14, 2002 | 02:12 AM
89 TA's Avatar
Engine: 383/435 Cat
I thought the ESC was code 43. I looked it up in the manual at school and it said it was either the ignition module, the wiring, or the ECM. and everything seems to point to the ECM. I already put a new module and semi-checked the wiring, so I'm guessing it's the ECM.
Old Jan 14, 2002 | 02:44 AM
86_Dan_Z28's Avatar
Car: 86 Z28
Raul, if you need a knock sensor I have a spare one from a 305 lying around, you can have it if you need it.
Old Jan 14, 2002 | 09:32 AM
Kevin91Z's Avatar
Code 43 is the knock sensor, Code 42 is the ESC.
Old Jan 14, 2002 | 12:12 PM
Russ-So Cal's Avatar
Don't give the wiring a quick glance. The ecm works by sending signals to sensors which are variable resistors and then reading the return signal. Anything that causes resistance will throw the signal off. Make sure all connections are clean and tight before you condemn the ecm.
Old Jan 14, 2002 | 10:26 PM
BLWR PWR's Avatar
Car: 89 IROC
Engine: Built 383, Vortech SC
Transmission: Pro-Built 700R4
Axle/Gears: Dana 44, True Trac, 3.54
Code 42 is EST(electronic spark timing). Check ig. module, wiring , and ecm. Code 43 is ESC(electronic spark control) knock senser,and the related circuits. I am still chasing an intermittent code 42 and it is driving me crazy. Kevin burned me a great chip and the car hauls *** when the code is not set. It will set it only on start up sometimes, not all the time. I shut the car off, clear the code, start it up, no code, go for a haul butt drive. Then I can shut it off and the next start up get the code, sometimes i dont get it for four or five starts. Car runs great besides the clearing the code every few starts. Ill get it sooner or later.
Old Jan 14, 2002 | 10:49 PM
Kevin91Z's Avatar
You're right Jeff, I was mixing up my acronyms. Code 42 is the EST, the timing adjustment part. Code 43 is the ESC, the knock sensor part.
Old Jan 14, 2002 | 10:50 PM
89 TA's Avatar
Engine: 383/435 Cat
BINGO! Exactly what my car is doing. Just this weekend a two-way trip to my mom's took me less than 1/4 tank w/o the light. on sunday it swallowed almost 1/2 a tank one-way. normally it always runs about 160-170* w/o the light, with the light it runs about 220-240*. Let me know if you ever find the solution.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
