How long do bronze dist. gears last?
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I have had bad luck changing my distributer in the past, so I am thinking of putting a bronze gear on my new (used, but new to me) MSD pro billet dist.
When I first installed my new engine with the "Hot cam" I put the stock distributer back in and about 6 miles down the road the car died. Come to find out, the gear ate itself, or the cam gear ate it. I did alot of research and found I had the right gear on the dist. but it had a wear pattern and the new cam did not. I bought a new "melonized" gear from GM and it has been fine since. Now, the cam is about 2 years old and I want to put a new dist. in, but the gear on the dist. is slightly used. Should I put a new "melonized" gear on or use a bronze gear? I drive the car every day, so that is a factor. I refuse to pull the motor out and tear it down again for a simple but costly problem. Thanks guys/gals...
Jason
Jason
Can you remove the melinized gear from your current distributor and install it on the new one? That way you get a gear that has already been working with the gear on your cam, and the two should be seated in to each other.
ambainb
Apr 25, 2016 09:21 PM
gixxer92
Sep 1, 2015 04:32 PM
