1982-1992 Chevy Camaro Upper & Lower Door Hinge Pin & Bushing Kit Pair
Former Sponsor
![](http://1aauto-images.s3.amazonaws.com/partimage/DRK/1ADRK00074/main.JPG)
These replacement hinge pin & bushing kits are among the highest quality replacements on the market. They are just what you need to get your sagging door in good working order again!
Specifications:
Comes as a PAIR
Fits both LH (Driver Side) & RH (Passenger Side) Upper & Lower Door Hinges
Replaces dealer part numbers: 20043321, 9721917
Direct replacements
Built to strict quality control standards
Each kit includes:
(3) Steel Hardened Pins
(1) 0.380" x 4"
(2) 0.584" x 1.031"
(2) Bushings
(2) - 0.866"ID x 0.590"OD x 0.248"
(2) -0.344"ID x 0.490"OD x0.370"
(2) Lock Nuts
(2) - 5/16"-24
NOTE: This pin & bushing kit has enough parts to repair both doors. If you need to replace 1 door, please see our other listings.
Replace your worn hinge pin & bushings with these great fitting repair kits!
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
Specifications:
Comes as a PAIR
Direct replacements
Each kit includes:
(1) 0.380" x 4"
(2) 0.584" x 1.031"
(2) Bushings
(2) Lock Nuts
(2) - 5/16"-24
1 Year Warranty
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
