Torque Arms.
Old Apr 16, 2002 | 10:31 AM
Ezey Go's Avatar
Torque Arms.
What is the best torque arm for our cars?I was looking at Sophens,does any have his and do you like it?Thanks.
Old Apr 16, 2002 | 06:58 PM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
Is that a misprint? Were you trying to write SPOHN? If you meant the SPOHN torque arm then yes, i have one and it is awesome. I run on street radials at the track and have managed a 1.91 60ft time with it, before i couldn't even get below a 2.2
Old Apr 16, 2002 | 08:04 PM
87RS402's Avatar
I'm going to go witht eh BMR trak pack arm. I want a shorter arm than what Spohn has to change the instant center of the rear suspension up and back a little more.
Old Apr 16, 2002 | 11:20 PM
JERRYWHO's Avatar
If you are looking for a short style arm and you drive on the street look at the global west torque arm. I will be installing one on my car this weekend and one more good point about Globalwest arm is that it's a bolt on unit.
The link for them is www.globalwest.net
Jerry
Old Apr 16, 2002 | 11:21 PM
JERRYWHO's Avatar
One more picture.
Old Apr 17, 2002 | 12:41 AM
87RS402's Avatar
I appreciate that info Jerry, I'll look into that one.
Old Apr 17, 2002 | 08:29 AM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
Slush -
What did you set your pinion angle at? I have mine at 0 degrees, and my 60 foots got worse. I was wondering if going do -2 or so would be an improvement.
Did you get the arm and crossmenber with the ds loop? If so, do you have any problems with the loop hitting the arm at any time?
Old Apr 17, 2002 | 05:05 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
JERRYWHO,
Keep us updated on how your install goes, I'm also interested in this subject.
Also, I like the work of art that has been fitted to that manifold. did you do it yourself?
Rob
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
