Need Moog part#'s
Old Apr 16, 2002 | 10:31 PM
steve8586iroc's Avatar
Need Moog part#'s
I plan on a complete frontend rebuild for my 91RS and cannot find the part#'s for the Moog HD peices. I want the best parts available.
Thanks, Steve
Old Apr 17, 2002 | 07:09 AM
LimaBravoNiner's Avatar
Car: 89 GTA, 89 Formula
Engine: L98, LB9
Transmission: Auto, 5-Speed
Here is a list of the parts I used:
Moog
K6145 Lower Ball Joint
K6249 Idler Arm
ES2226RL Outer Tie Rod
ES2227RL Inner Tie Rod
DS1049 Drag Link
Monroe
901923 Upper Strut Bearing Plate (LH)
901924 Upper Strut Bearing Plate (RH)
Good Luck
Old Apr 17, 2002 | 09:48 AM
vjo90RS8's Avatar
Car: 2002 Z28
carparts.com has Moog parts, i use their site to check the part number and then enter that number on summit's site.
Old Apr 17, 2002 | 05:45 PM
Thanks for the bone guys.
Steve Dog
Old Apr 17, 2002 | 11:02 PM
rezinn's Avatar
Notice any difference after installing those pieces?
Old Apr 18, 2002 | 12:58 AM
Jza's Avatar
Jza
I used all the same part numbers, except the lower ball joints, where I used K6145T, which is the heavy-duty light-truck ball joints.
Probably not going to notice a difference if your suspension is fine, but if it's sloppy or bent, then, yeah obviously there's a noticable difference. Moog makes good parts, but the performance increase by using them instead of cheaper parts is going to be in longevity and strength, not an actual driving performance increase.
Old Apr 18, 2002 | 06:44 AM
Engine: L98, LB9
Yeah, what Jza said.
Old Apr 18, 2002 | 12:00 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
The only heavy duty parts that Moog makes are the tie rods right?
87v6Bird
Jul 1, 2018 04:12 PM
BumpaD82
Feb 26, 2016 02:57 PM
starfinder
Oct 25, 2015 10:40 AM
loud91rs
Oct 5, 2015 10:05 PM
jtwoods4
Sep 3, 2015 10:19 AM
