Orientation of rear springs to get an even ride height.
Old May 2, 2002 | 10:45 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
The rear drop springs I installed are not even. There is almost an inch difference between each side. When I was installing them I noticed that the position of the springs had a lot to do with how high the spring sat. Does anyone know where the end of the spring should be on each side? I can't find it in the manual either. I know I saw it on here but I think that was just for the front springs.
Old May 2, 2002 | 12:07 PM
Camar_Hunter_c's Avatar
did you take out 1 mounting and not the other?...
Old May 2, 2002 | 02:29 PM
Omega's Avatar
Engine: LS1 / LS3
Nope, both of the isolators are where they are supposed to be.
Old May 2, 2002 | 03:32 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
A 1" difference is an awful lot. Are you sure the springs are seated correctly?
The orientation of the rears isn't as critical as the fronts. Just make sure BOTH springs are oriented the same and you should be fine.
Old May 2, 2002 | 04:07 PM
Omega's Avatar
Engine: LS1 / LS3
Seated correctly? As I raised the axle back up I jostled the springs. The bottom of them are seated around the lip... what could I have missed?
Belltech drop springs give you a 1.5" drop correct?
Old May 2, 2002 | 04:12 PM
Car: Yes...
There's also a lip up in the frame. Make sure the springs fit around the lip at the axle AND at the frame.
I'm not sure about the Belltech spindles. Check their web site. Info. should be there.
Old May 2, 2002 | 04:42 PM
Omega's Avatar
Engine: LS1 / LS3
OK, now I am scared.. after moving the car 20 feet and letting it sit overnight they are now equal. I SWEAR they were different yesterday!! I have a witness!
Thanks for the suggestions.
Old May 2, 2002 | 06:27 PM
pianiy's Avatar
Hey Tim, they could have settled in the movement, possibly from a temperature gradient as well, expanding/contracting with the weather. Good luck with the install, I'm still working on mine, heh
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Aug 26, 2015 03:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
