front suspension settings
Old May 6, 2002 | 12:23 PM
ROB87GTA's Avatar
although my gta handles ok, i think my tracking needs to be looked at,
could someone post the settings for toe,camber,etc...
bearing in mind that i live in england would the settings need
to be reversed.
Old May 6, 2002 | 01:17 PM
pianiy's Avatar
These specs are from Guldstrand Motorsports who are experts when it comes to suspension components, particularly on F-bodies.
This is what they suggest:
For RACING:
Camber: 1* to 1.5* NEG
Castor: 4* to 5.5* POS
Toe-In: 0" to 1/16" IN
For SLALOM:
Camber: 1/4* to 1/2* NEG
Castor: 3.25* to 3.75" POS
For TOURING:
Camber: 0* to 1/4* NEG
Castor: 3* to 4.25* POS
No difference from them between the left and right side.
Old May 6, 2002 | 01:20 PM
pianiy's Avatar
Oh and according to the Haynes manual these are the stock settings:
82-86:
Caster: 3.00*
Camber: 1.00*
Toe-In: 3/64"
87-90:
Caster: 4.7*
Camber: 0.30*
Toe-In: 0"
91-92:
Caster: 4.8*
Camber: 0.30*
Toe-In: 0"
Old May 6, 2002 | 01:42 PM
ROB87GTA's Avatar
thanks for the reply pianiy
i have both haynes and chilton manuals just curious as to
wether there was a better set up and the fact that english
roads crown in the middle
thanks Rob
Old May 6, 2002 | 10:20 PM
pianiy's Avatar
thanks Rob
So do ours... so do ours... its for drainage.. sucks... good luck.
Old May 7, 2002 | 08:53 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
thanks Rob
make the caster about .5 degrees higher to offset for the road crown.
here's what i suggest.
camber left -.5 right -.5
caster left 4.00 right 4.50
toe left .03 right .03
Old May 7, 2002 | 08:56 PM
Dex's Avatar
Dex
They drive on the left instead of the right (freaks) J/K:lala:
so i would say just switch the castor and that should be fine
Old May 7, 2002 | 09:37 PM
mrr23's Avatar
Engine: 360 HSR
yep. i didn't catch his place of residence. so yes make the caster higher on the left side.
Old May 8, 2002 | 06:53 PM
ROB87GTA's Avatar
mrr23 and dex
thanks for the answers boys
i know it sound strange driving on the
wrong side(lol) but surly things like tracking
have to be reversed cos i drive on the wrong
side.......
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
LT1Formula
Nov 16, 2015 01:13 PM
TheExaminer
Aug 25, 2015 07:34 PM
