I dont get it, brake bleeding
Old May 10, 2002 | 03:20 PM
86bird_28v6_5spd_ramair
Guest
Posts: n/a
I need to bleed my rear drums. I found the bleedser, they had nice rubber plugs over them but it is just a nipple.
Just a nipple. no place for a wrench.
Old May 10, 2002 | 03:32 PM
Guest
Posts: n/a
on a normal GM car there is a nipple with a wrench spot under it, now many times they are broke off but it is then flush.
these just have a nipple, how do I losen that. vise grips.
Old Nov 24, 2002 | 10:38 AM
CHEVY85Z28's Avatar
Rear Drum Brakes Bleeding
I'm having the same problem, I called the dealer..no help. Then I called "Just Brakes"...no help either. I tried to put a socket on it that didn't work. Somebody tells us how to bleed the back drum brakes.
Old Nov 24, 2002 | 04:41 PM
4MULA88's Avatar
Car: 83 T-top T/A, 92 RS
Engine: 1970 LT1,305 TBI
Transmission: Th-400, 700r4
Axle/Gears: 3.42,2.73
TTT
I need help 2
Old Nov 25, 2002 | 03:43 PM
4MULA88's Avatar
I know someone has done this
HELP:hail:
Old Nov 25, 2002 | 03:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
With a socket.
You might not have seen it yet, but it's there. 5/16" hex IIRC. Use a 6-point deep-well to avoid rounding it off.
Old Nov 25, 2002 | 07:08 PM
ronterry's Avatar
Car: '94 Corvette
I think it's 8mm (deep Z neck) - closed end, and aviable from GM.
(It's looks like a miniture version of a GM distributor wrench.)
I bought one from Checker Auto, but didn't go deep enough. I ended up doing a litttle grinding on one side with my dremel.
It's a stupid design, and a PINA... I even looked at replacment pistons at Checker, and there all the same!!! It's stupid...
Grinded it down did work though...
Ron
Old Nov 27, 2002 | 11:52 AM
4MULA88's Avatar
Thank you for the help guys
:hail:
83 Crossfire TA
Jan 3, 2016 01:26 PM
dbrochard
Sep 19, 2015 08:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
