a very hard ?, need help and ideas.
Old May 22, 2002 | 08:08 AM
iroc111's Avatar
just had all four springs replaced with the Eibach pro-kit, and had the shocks and struts replaced with KYBs. the ? is in the right rear of the car is sitting about a 1/2 inch to 3/4 inch lower than the left (driver) side. the weird thing about is that it sat like this with the factory springs as well.
what can i do to correct this? could i put a spacer in the springs to give more lift?
its a 1987 Iroc-Z
Old May 22, 2002 | 09:44 AM
chevyguy1969's Avatar
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
I would make sure you dont have any damaged components. Also, make sure the springs are seated correctly. Did you do the work yourself or have a shop do it?
Old May 22, 2002 | 10:30 AM
iroc111's Avatar
i had the shop do it, but i was there and everything seemed okay, the funny thing is that it sat the same way with Iroc springs.
Old May 22, 2002 | 12:09 PM
urbman's Avatar
I would say you need to make some measurements.
I am guessing that you have determined this by
say eyeballing the fender wells....
1. Park it on a level surface.
2. Measure the distance from the lower control arm mounts to the floor.
(both sides)
3. Measure the distance from the front A-arm mounts to the floor
(both sides)
4. Put the car on jackstands. The jackstands should be under the
a-arms in front and under the axle in the rear. The car must be
a good aproximation of "level"
5. Measure the distance from the spring perch to the frame
(both sides)
6. Measure the distance from the a arm to the K member
This should give you a pretty good idea as to what to do
next....
Old May 22, 2002 | 12:12 PM
Engine: LS1 V8
I think urbman has a good idea. Post your results after doing that and we can take it from there.
Old May 22, 2002 | 12:23 PM
iroc111's Avatar
okay thanks guys, i'll try to do it in the next few days. I'll pull it into my job warehouse area, that should be pretty level.
Old May 22, 2002 | 03:23 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I'm not sure what year your car is but I have a printout of all the measurement of the chassis for a 91' Camaro, the type that professional body shops use for their frame racks. If your interested I can try and get it scanned for you.
Old May 22, 2002 | 04:19 PM
Buck268's Avatar
I have the same uneven rear end problem. My dad said just get Air Shocks and be done with it - which I might *shrug*, but i kinda wanna make sure its not a big deal first (like a busted LCA or something)... Anyways, if you get that data sheet scanned up, please send it to warlord_600@hotmail.com!!
RedLeader289
May 28, 2019 01:47 PM
Mark_ZZ3
May 24, 2018 01:02 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
loud91rs
Oct 5, 2015 10:05 PM
