drum to disk conversion?
Old Jun 13, 2002 | 07:46 PM
Tas's Avatar
Tas
any writeups? How much of a pain is it? are junkyard parts needed or can you get new disks and stuff from the auto part store? what about 1LE stuff?
Old Jun 13, 2002 | 08:18 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I will soon be offering such a kit. Completely painless, and includes everything. Even gear oil! I will keep you posted.
This kit will also work on converting the early 3rdgen disc brake rears to the later (PBR) style disc brakes.
I really is a pretty slick setup.
Thanx,ANDYZ28
Old Jun 13, 2002 | 09:41 PM
Tas's Avatar
Tas
killer
Old Jun 13, 2002 | 11:13 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Thanx,ANDYZ28
Yeah, that sounds great!
So it means I can take my 86 drum rear and just install your disk brake setup in place of the drums?
Whoa, that will be slick :hail:
What about the master cylinder? I've heard that even GM allowed the use of the drum master cylinder in disk rear upgrades.
Old Jun 13, 2002 | 11:43 PM
iroc22's Avatar
The drum/disc cylinder was used for the 1LE. It's the proportioning valve you need to change.
Old Jun 14, 2002 | 01:37 PM
PonchoTA's Avatar
Andy, I hope you don't mind me jumping the gun on this, but
Tas, I just installed ANDYZ28's preliminary kit and it actually was
painless!
Everything I needed was sent right to my doorstep, and with a
buddy's help, common sense, a few handtools, and a manual, I
tried out the brakes within about 4 hours!
I am totally pleased with the support I've received, quality of
materials and speed that I received the kit!!
I will be getting more stuff from you later Andy!
Hope this helps your decision Tas!
Old Jun 14, 2002 | 05:15 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Woah, sweet..
any sort of info on how much this will cost?
Old Jun 25, 2002 | 04:15 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Originally posted by Sonar_un
Woah, sweet..
About $731.00 plus shipping.
Old Jun 25, 2002 | 06:20 PM
Tas's Avatar
Tas
how do these brakes compare to LS1 rear disk brakes? Are they original 1LE spec? powerslots?....
Old Jun 25, 2002 | 08:52 PM
ANDYZ28's Avatar
Car: 1982 Z-28
I have never driven an LS1 equipped car. They are all "ABS" equipped. So a comaprison would be very had to make.
These are 1LE spec. But the backing plate is much beefier. The original 3rdgen "PBR" backing plate is a stamping and rather flimsy. Mine is a dramatic improvement.
I will have many quality images of this conversion on my NEW "CD".
I am attaching an image to illustrate this point:
Thanx,ANDYZ28
Attached Thumbnails drum to disk conversion?-installed-backing-plate-resized.jpg
Linson
Oct 24, 2025 02:00 PM
92projectcamaro
Dec 8, 2015 12:25 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
