Thunk noise in rear
Old Jun 17, 2002 | 06:21 PM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
Thunk noise in rear
I just noticed a new thunk noice (almost like droping a bolt in a plastic bucket) in the rear of the car. It only happens when I swerve the car back & forth in ether direction, even at slow speeds.
No evidence of the tires rubbing.
Stock springs and sway bar but with poly endlinks.
koni shocks
Edelbrock tubular panhard bar.
Stock arms with new 1LE bushings.
Torsen diff & 3.42 gears.
The rest is stock
Nothing been change for 3 months.
Any ideas?
Old Jun 17, 2002 | 06:29 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
I had a similar sound once, but it was because my spare tire wasn't secured in place. It would bump against the inside of it's housing, and really freaked me out.
Hopefully you have the same problem! It's a cheap fix. ; )
Old Jun 19, 2002 | 08:16 AM
Axoid's Avatar
Car: 92 Camaro RS
Nope, the tire was secure, but I tightened it up more and the sound is still there.
Old Jun 19, 2002 | 08:50 PM
STEVE-83Z's Avatar
Car: 83 Z28 Camaro
Engine: 355 Holley Projection
Transmission: TH400
Axle/Gears: 10 bolt Zexal 3.73
Check bolts on the panhard bar. I had the same noise, sounded like the rearend was screwed up and only when turning. Found the bar loose. It was about a month after I put it on also. I guess you just have to tighten them after a thousand miles or so after installation. Hope this helps.
Old Jun 20, 2002 | 03:02 PM
Axoid's Avatar
Car: 92 Camaro RS
Haven't been able to thoroughly check, but I did look and the bolts look ok. I put the panhard bar on a year ago so if it was going to loosen you'd think it would have done so long before now.
Old Jun 20, 2002 | 08:36 PM
STEVE-83Z's Avatar
Car: 83 Z28 Camaro
Transmission: TH400
Try to tighten the bolts. They will look normal, and still be loose. I am pretty sure this is your problem. Keep us posted.
Old Jun 21, 2002 | 01:47 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
Check your end link to your sway bar on the rear-end. My friend's car did that and he had a broken end link on his sway bar.
Old Jun 22, 2002 | 06:43 AM
Axoid's Avatar
Car: 92 Camaro RS
Good call. One of the bolts was ~10 ft.lbs. light. Tightened it and regreased the fittings and took it for a test. No thunk.
Old Jun 24, 2002 | 08:22 PM
STEVE-83Z's Avatar
Car: 83 Z28 Camaro
Transmission: TH400
Good !! I knew it sounded like the same problem I had. Good Luck with it !!
theshackle
Sep 17, 2020 08:26 AM
Fronzizzle
Mar 18, 2019 08:29 PM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
