Awww, I messed up the brake caliper bleeder.... what do I do now?
Old Jun 26, 2002 | 10:18 PM
GoldenSwordZ28's Avatar
I just got my new rotors, seals, bearing, brake pads and brake calipers on.... and low and behold when I went to bleed the system, that little silver nozzle that lets you bleed from the caliper just stripped and went round. How in the world do I bleed the brake system now without having to buy a new caliper???? Especially after getting everything on there. Welp, any help would be appreciated it. Thanks!
Adam
Old Jun 26, 2002 | 10:45 PM
AFrikinGoodTime's Avatar
If it is only the bleeder valve that is stripped, Call around to find sone Earl's Solo-bleed valves. If you have the iron calipers (non-1LE) the part # for solo-bleed's is #280029. This # will work for fronts and rears and sells for aprox. $9 a pair.
Old Jun 26, 2002 | 10:54 PM
But what are they? I was just looking to see if there was anything I can do tonight, seeing as I have to use the car in the morning.
Adam
Old Jun 26, 2002 | 11:04 PM
Its called a bleeder valve, any autoparts store should have them but you'll probably have to take a good one off the car to match it up.
Old Jun 27, 2002 | 01:17 AM
Problem is, that the hex on top is stripped. So its round now.... and I can't get it off, theres no possible way that I can think of.
Adam
Old Jun 27, 2002 | 11:20 AM
wuter's Avatar
try vise grips
Old Jun 27, 2002 | 12:21 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I second the vise grips. Also try a socket that is one size too small (hammer it on), channel locks might also work.
I don't recomend heating it up.. it could work but caliper damage can occur.
Old Jun 27, 2002 | 12:54 PM
ede's Avatar
ede
you might want to heat it a little and try vice grips or a pipe wrench. if that doesn't work tertron makes a repair kit. you drill out the bleeder and tap it to 1/4" npt then screw in a new valve and seat assembly.
Old Jun 27, 2002 | 01:26 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i have used both ede's and omegas methods. they both work very well. the pipe wrench works much better than vise grips. if it is the front caliper (non-1le) you coud get another rebuilt caliper for $15. that will save you some time and hassle.
Old Jun 27, 2002 | 09:51 PM
I really appreciate all the help guys. I'm going to be trying this somtime tomorrow and see how it works out. I'll see what works best I'll let you know what happens either way.
Adam
Old Jun 28, 2002 | 12:11 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Soak the hell out of it with penetrating oil and let it sit for a while first. THEN use a BFPR on it.
Ed
PS: BFPR=Big Friggin Pipe Wrench
Old Jun 28, 2002 | 04:56 PM
RJR99SS's Avatar
ALWAYS use flare nut wrenches when you work on anything related to the brake lines...
Old Jul 1, 2002 | 05:57 AM
ebmiller88's Avatar
I agree, always use flare nut wrenches on brake lines, UNLESS they're already screwed up.
Just get a new caliper, they're cheap and it'll save you time.
dbrochard
Oct 3, 2015 12:43 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
