how long before my poly bushings squeak?
Old Jul 9, 2002 | 10:23 PM
breathment's Avatar
I jsut got my control arms put in today after replacing the bushings.. i must say this is the first time i'v worked on my car for something major without anything going wrong!!!! I was suprised at how easy it was.. even with that stupid spring compressor.. How long should i expect before the pre-lube grease i put on wears off and everything starts squeaking like crap?? i took it for a drive tonight, and it was suprised how much everything tightened up, understeer was reduced alot (replaced sway bar bushings too).. i was driving and did some quick "evasive manuevers" and was suprised at how well the front tires stuck to the ground, i feel like i could easily manuever through hundreds of dogs crossing the highway!!
best part is no squeaks, yet... Im getting new tires tomorrow so i can't wait until then to test out everything new..
the only problem i DID have was i didn't realize the bolts for the control arm were different sizes... So one side got the long ones, the other got the short bolts... I'll have to fix that one day..
Old Jul 10, 2002 | 12:48 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Mine only squeak after I drive through big puddles after it rains. After a big puddle, the next few days it will squeak and slowly go away over a week.
Old Jul 10, 2002 | 05:43 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Over 15,000 miles later, and mine still don't squeak.
Thanx,ANDYZ28
Old Jul 10, 2002 | 11:38 AM
86IROCZ's Avatar
Same here, It's the sway bar ones that do it. I've been meaning to get down there and regrease them. Maybe I'll get some greasable ones.
Old Jul 12, 2002 | 12:26 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I don't know. Becasue I converted mine to be greasable (that's been over 3 years now). FYI, I had enough requests for them that Top-Down Solutions will be adding greasable front and rear sway bar bushing kits to our inventory in roughly 1 week. I'm just waiting for the brackets and bolts to return from being zinc plated and more bushings to arrive from Guldsrand so I can modify them to be greasable. Oh, FYI, the brackets on the Energy Suspension greasable front sway bar bushing kits have a straight slot pattern which will ONLY fit on a 1982 F-Body. 1983-92 F-Bodies have an offset bolt mounting pattern, so they will not fit. My version will fit all 1983-92 F-Bodies with the exception of 1989 TTA's. Lon
Old Jul 12, 2002 | 06:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Lon,
When you're ready to distribute your greaseables, please let me know. I'm very interested.
JamesC
Old Jul 12, 2002 | 09:18 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Hey Lon, should I just send you my Guldstrand bushings? I haven't messed with them yet, just took them out to play with them. I could pre-pay you for my kit and you could send it out when it's ready.
No real hurry, but I NEED it before the 1st of August.
Ed
Old Jul 12, 2002 | 11:09 AM
lonsal's Avatar
Ed, yes send them to me and I'll modify them. I'll deduct my cost for them from the kit price. You'll have the kit in hand in plenty of time. The brackets went to plate Wednesday and will be plated Monday (yellow zinc). Once back, I'll just have to install the zerk fitting and grease fitting cover and package. Any preference on color for the grease fitting cover? Black will be standard, but blue and red are also in stock. If you don't have it you should pick up a set of my grease fitting covers then too (currently on sale). A pack of 10 will be enough to cover all 9 fittings on the front suspension.
I'm including zinc plated bolts with the kit. It cost an extra lot charge to get them plated, but I want to include them because many of my customers have a lot of rust issues.
Lon Salgren
Top-Down Solutions
PO Box 5601
Hacienda Heights, CA 91745
Details of "Sale" referenced above: https://www.thirdgen.org/techbb2/sho...hreadid=118902
Old Jul 12, 2002 | 02:19 PM
ebmiller88's Avatar
Thanks Lon, sending you mail.
Ed
Old Jul 16, 2002 | 09:57 PM
lonsal's Avatar
Ed, I got your brackets and sent you e-mail. I will be finalizing pricing on the greasable front and rear (yes I have a VERY FEW rear kits available) sway bar bushing kits. The brackets came out real nice. They are plated yellow zinc. I also plated the mounting bolts (or in the case of the rears U-bolts and hanger brackets)and include them with the kit. Brackets are drilled & roll-tapped prior to plating and have a zerk fitting installed. A grease fitting cover protects it from debris between lube jobs. I am using Guldstrand Motorsports poly-graphite bushings exclusively. They are specially modified by drilling through to the ID, then I make 3 circumferential grooves on the ID and a double-cross groove for the grease to flow all around the sway bar. E-mail me if you want a set. Lon
Old Jul 18, 2002 | 09:44 PM
lonsal's Avatar
OK, I've assigned a p/n for the front greasable sway bar bushing kit. I've also established pricing. TDS p/n 200170-36, -34 & -32 (designating 36mm, 34mm & 32mm Guldstrand Motorsports poly-graphite bushings. Retail Price is $39.50. I can also offer it ala carte: Sway bar greasable bracket kit (less bushings) is 200170-NB, $13.50. I'll supply details on how to modify your own bushings to make them greasable. I can also modify a customer supplied bushings and include it with the brackets, that would be 200170-CB, $18.50. I'll start packaging them tomorrow. E-mail me at: topdownsolutions@yahoo.com if you want a set. I also have a very limited supply of rear bushing kits as well. Lon
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
luvofjah
Sep 10, 2015 10:41 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
