Weight loss!!!
Old Jul 10, 2002 | 04:42 PM
Marty'82T/A406's Avatar
Weight loss!!!
Got a few questions. I used to have an ls1 z28 that I got down to 2950lbs w/ me in it. It was a 11.6's bolt-on car. I now have a third gen t/a and am looking to lose some weight on it. So far I have removed the front sway bar and the panhard rod stabilizer bar(above panhard rod). What else is an easy way to lose weight on these cars? Draglites are on the way. A/c and heater are comin out. I would like to keep a basically stock interior(no taking out seats(front ones) or carpet)) but get the car as light as possible. Any suggestions?
Old Jul 10, 2002 | 04:50 PM
Tas's Avatar
Tas
https://www.thirdgen.org/newdesign/t...ngpounds.shtml
Old Jul 10, 2002 | 07:00 PM
Thanks !!!!!!! exactly what i was looking for
Old Jul 11, 2002 | 08:23 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
How did you get your ls1 car down to 2950 with you in it?
Old Jul 11, 2002 | 12:44 PM
ATOMonkey's Avatar
They're most made of plastic from what I understand.
Old Jul 11, 2002 | 12:48 PM
I ordered it for the factory with noooooo options cept 3.23's. Stock it was 3350 w/ me in it and almost no gas. Loosing a few hundred pounds isn't too hard
Old Jul 14, 2002 | 06:14 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
While pulling parts at the local Pick-a-Part for a future product I discovered the threads on most of the fasteners are way too long. By removing them and either getting shorter bolts or cutting and chamfering the threads you can loose some weight.
Old Jul 17, 2002 | 04:44 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
If you do remove the rear seats you could also remove the seatbelt assemblies which are quite weighty.The front ones could be replaced by harnesses if you want.Theres also the front seats themselves which could be replaced with light aftermarket ones.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
3.8TransAM
Sep 27, 2015 08:37 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
Damon
Sep 26, 2015 04:29 PM
