Two quick sway bar questions
Old Aug 9, 2002 | 10:07 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Two simple questions about installing sway bars.
First, should the front brackets be a perfect "U" shape, or slightly curved towards the front of the car?
Second, when installing new end links with polyurethane bushings, how much torque? Correct me if I'm wrong, but polyurethane bushings don't compress like rubber bushings.
Old Aug 10, 2002 | 10:15 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Please guys, I'd like to get this finished.
Old Aug 10, 2002 | 02:30 PM
camaroguy99's Avatar
The brackets should be pretty much U shaped, does the U bolt fit into the top part of the bracket? If so I guess put the slightly curved part toward the front. As for the torque it's not much. About 15 lbs. Mine came with nylock nuts, so I just tighened them down snug then about another turn or so. Remember when your're doing the endlinks. Make sure the suspension is loaded when tighening. This is very important.
Old Aug 11, 2002 | 09:13 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
U-shaped. 13 ft-lbs (18 N-m). Since you have to replace one, this is something to consider...
https://www.thirdgen.org/techbb2/sho...hreadid=122861
Lon
Old Aug 12, 2002 | 11:20 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Tighten the end links down until the bushing is almost flush with the side of the washer. I don't kow how much torque this will equal, though. Just don't tighten them down to where the bushing is squishing out the sides.
Ed
Old Aug 13, 2002 | 02:46 PM
WS6 Berlinetta's Avatar
what happens if the endlinks are too tight?
R
Old Aug 14, 2002 | 08:15 AM
ebmiller88's Avatar
My guess would be premature failure of the bushings from undue stress placed on them by excessive compression...My best Haynes manual explaination.
Ed
Old Aug 16, 2002 | 08:14 AM
lonsal's Avatar
Ed
I see you aren't using GM 1LE bushings Ed. The 10221779 1LE link assembly (aka end link kit) includes nylon bushings with a molded lip that the washer sets in. Just follow the torque recommendations. Yes you'll deform them badly if they are too tight. I don't know if that will cause a problem, such as binding.
Lon
Old Aug 16, 2002 | 10:45 AM
ebmiller88's Avatar
Nope, ES polyurethane.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
