1LE Steering box
Old Oct 6, 2002 | 09:44 PM
RareSUV's Avatar
1LE Steering box
ok, i hope this is the right forum for this. can anyone tell me the steering ratio of the 1LE F-Body steering box? and/or if there is a faster ratio than the 1LE box? any info or ideas would be appreciated.
Old Oct 7, 2002 | 01:51 AM
pianiy's Avatar
Ratio is 2.25 turns lock to lock and you simply can't tell my looking at it (as far as I know). I know this because the usual tell tale Z thats stamped on it was also stamped on my non-1LE box that I took out. You simply have to count the revolutions.
I heard about an aftermarket steering box but forget the name of it. There was also one (may have been the same and only aftermarket unit that I'm thinking about) that I've heard problems where it leaked or had dead zones. Do a search on it.
Old Oct 7, 2002 | 12:00 PM
RareSUV's Avatar
thanks for the info. Usually I just check the RPO tags on the cars and looks for one with the 1LE option. Im just trying to do a little research as to what cars came with what gears. I know ZQ8 S-Series trucks have a 12.7 : 1 ratio, but I heard the 1LE F-bodies had a 12.0 : 1, not that its a big deal, but every little bit helps.
thanks again for the help.
Old Oct 7, 2002 | 02:12 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
If I remember straight, the IROC/1LE steering box has a part number stamped on the box that begins with something like 26000xxx. Part numbers for the other boxes are considerably different. The 'Z' stamped on the box has nothing to do with the equation, as far as I know.
Old Oct 8, 2002 | 01:07 PM
Ed Z28 350's Avatar
All IROCs, Z28's, Trans Ams and Formulas have 12.0:1 boxes.
If the IROC, Z28, T/A, Formula came with 15" wheels, the box has 2.5 turns lock to lock. Many other GM cars came with 2.5 turns and were not 12.0:1 boxes.
Cars originally equipped with 16" wheels have larger internal stops (to limit wheel to wheelwell contact) which limits the box to 2.25 turns lock to lock. I can think of no other car with a 2.25 turn box.
If you find a 2.25 turn box, chances are excellent that it is a 12:1 box.
If you find a 2.5 turn unit, there is no guarantee that it is 12:1.
Hope this helps.
Old Oct 8, 2002 | 09:20 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I think AGR makes a steering box with a 12:1 ratio. A little pricy though; around $350 or so if I remember correctly. www.agrperformance.com
Old Oct 10, 2002 | 08:21 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Don't quote me on this, but it is my understanding that the quick ratio steering box for the 3rd gen. F-body was 12.7:1. That's what is supposed to be on my GTA. I haven't heard of a 12:1 box from the factory.
Old Oct 17, 2002 | 03:56 PM
01 FS Z28's Avatar
I got led down this "1LE steering box" trail..... Turns out, I can't find any data that supports it's existence. Let alone the fact my '91 1LE has the same quick ratio box that other 16" wheel f-bodies and even Grand Nationals have.
Old Oct 18, 2002 | 08:32 AM
Ed Z28 350's Avatar
Come to think of it, I think you're right
83 Crossfire TA
Jan 3, 2016 01:26 PM
punkmaster98
Sep 8, 2015 09:45 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
