Control Arm Relocation Brackets
Car: 4
Engine: 6
Transmission: 5
No. Unless of course you lowered it by using tiny tires... the brackets go on the rear end, so as long as the tires are a reasonable size, they'll fit fine.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The picture is good. You'll notice that the suspension parts don't go below the bottom of the rim.
A lowered car really needs relocation brackets. You need to keep the LCA parallel to the ground or slightly higher in the front. Doing this will reduce or eliminate wheel hop.
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I've been wanting to build a set of these. How far below the origional lca mounting holes are the relocated mounting holes? are they directly below?
thanks , Kory
thanks , Kory
Car: 87 IROC L98
Before I went to ladder bars I made a set for my old diff. I had 3 holes. 1", 2" and 3" lower than stock. The 3" hole put the rear of the control arm lower than the front.
Car: 88 Iroc
Transmission: t 56
Great info thanks.
Bill could you email me that autocad drawing? My email is imkory@yahoo.com. thanks alot
Kory
Kory
Car: '84 Trans Am
Engine: 350ci Sportsman heads, B&M blower
Transmission: Turbo 350
Me too. Thank you very much, coddog17@hotmail.com
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
Car: 98 Camaro SS
Transmission: M6
I too am interested in the drawing. Could you please send it to 700r4@popmail.com . Thanks!
Car: Trans Am -84
Engine: 355, Twin Turbo
Axle/Gears: 3.73 open
Would really appreciate if you could email me the drawing.
mailto: v8guy@home.se
/Anders
Webmaster: Trans Am Cluf of Sweden
http://www.tacs.nu
/Anders
http://www.tacs.nu
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
Me too please! Psaitta800@cs.com
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
