Question for Hunter Motorsports
Old Oct 27, 2002 | 10:08 PM
Tom Keliher's Avatar
Karl, will the strut mount bearing assembly simply fall out when the snap ring is removed? Or is it a press fit?
If I remove it, is there a proper orientation I need to remember when reinstalling it?
Old Oct 27, 2002 | 11:19 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Well, I know for a fact it is a press fit. He told me that they made a special tool to remove it. I belive what he was explaining to me over the phone was that they have a piece of round steel that is 7/8" in diameter, and cut one end down to 3/4". Then, to make removal easier, heat the whole assembly in your oven. The aluminum will expand at a greater rate than the steel bearing. After heating, place the tool on the bottom of the bearing and push it out. I'm assuming re-installing would involved heating and pressing it back in. I dont have the mount in front of me, so I dont remember if those sizes for the tool are correct, but I am fairly sure thats what he told me. I'm sure he'll respond with a clarified version of what I just said.
Old Oct 27, 2002 | 11:20 PM
Scott_92RS's Avatar
Car: 1992 RS
Also, I'd like to know if there is a part # for that bearing, and if so, can we have it in case we need replacements for some reason. Where can they be found? Thanks!
Old Oct 27, 2002 | 11:24 PM
Thanks for the info Scott!
Old Oct 27, 2002 | 11:32 PM
Scott_92RS's Avatar
Car: 1992 RS
N/P FYI, that 1" diamter rod, needs to be 7/8", I THINK. Its either a rod that is 1" that gets cut to 7/8", or a rod that is 7/8" and gets cut down to 3/4". You could probably figure it out from looking at the part. I was trying to drive my new truck at and remember the bearing removal directions at the same time, lol.
Old Oct 28, 2002 | 12:19 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I though he covered that in the instruction sheet he sent along with the mounts? I've read mine once and put them away until I install them in the car.
Ed
Old Oct 28, 2002 | 06:19 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i don't remeber anything about rebuilding them in the instruction sheet.
Old Oct 28, 2002 | 06:43 AM
Scott_92RS's Avatar
Car: 1992 RS
Instruction Sheet?
Old Oct 28, 2002 | 07:16 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Originally posted by Scott_92RS
Instruction Sheet?
i got 2 peices of paper (stapled together ) that included a "i am not liable" thing , and it gave (sort of) instructions for installation.
Old Oct 28, 2002 | 08:24 AM
Scott_92RS's Avatar
Car: 1992 RS
Hmm, I didnt get anything with mine. Ya mind scanning them? No biggie if you cant though.
Old Oct 28, 2002 | 10:24 AM
Dewey316's Avatar
Car: 1990 Camaro RS
i don't have a scanner, but it would only take me a couple of min. to type it out. i will try to do that this afternoon, and i will atach a copy of it in word format (if you have word)... just let me know what version of word you need.
Old Oct 28, 2002 | 10:27 AM
Scott_92RS's Avatar
Car: 1992 RS
Thanks man, I apprecite it. I've got Word XP, but if you are going to attach it to a msg on the board, maybe Word 97 would be best, so others could open it up too. Thanks!
Old Oct 28, 2002 | 10:38 AM
Dewey316's Avatar
Car: 1990 Camaro RS
i can do both, i will attach XP, and some older version, maybe even 6.0, for those who are really old school, i will do it once i am home from work.
Old Oct 28, 2002 | 07:07 PM
Hunter Motorsports's Avatar
Car: Camaro Z28 1LE R7U
Engine: 5.0 TPI
Transmission: G-Force Dog-Ring T5
The bearing is an interfearance (press) fit.
Removing the snap ring will not allow the bearing to simply slip out.
The tool we made for installation and removal is not nesscsary - but it makes the job easier.
There is no special orientation for up and down - the bearing is symetrical.
When the strut is installed, the bushing inside the bearing must be at the bottom.
The bearing is an Aurora part# COM12
These bearings have proven to be very durable. Nobody should have to worry about them for years to come.
Old Oct 29, 2002 | 12:32 PM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Aurora bearing? That's damned fine quality
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
