Which LCAs
Old Nov 6, 2002 | 12:42 PM
TravisZ28MAXX's Avatar
Car: 1992 Z28 and 1988 IROC-Z
Engine: both L98s one with SD and one with MAF
Transmission: both 700R4s
Which LCAs
Hi, I just found out my LCAs are twisted, bent, just generally fuct up. So rather than replacing them with stock ones, I was just going to upgrade to tubulars or boxed, heres my question which brand to get, which options to get, etc...., Im pretty sure I need adjustables, but Im not sure whether to get poly ends or spherical rod ends. Heres why just in case someone waqs wondering, My car seems to pull most times, to which side apparently depends on its mood at the time, or how much weight its carrying and the such. thnx in advance.
Old Nov 6, 2002 | 01:09 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
what do you use your car for?
street driving?
drag racing?
auto-x?
if you let us know what you use your car for the most, it will help determine what parts are right for you.
Old Nov 6, 2002 | 02:00 PM
Street driving mostly but I plan on autocrossing it.
Old Nov 6, 2002 | 02:13 PM
Dewey316's Avatar
Car: 1990 Camaro RS
well for handling you want spherical bearings (no bind).
but if you mostly street drive you car they wear out.
i would sugest middle ground.
spohn poly/spherical combo LCA's.
or if you don't like the idea of the noise and fuss of sphericals get poly/poly.
Old Nov 6, 2002 | 04:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have the poly/poly Lakewoods (square tubing), they seem to work quite well. You don't need adjustables unless you are trying to adjust your car's wheelbase.
Old Nov 6, 2002 | 09:00 PM
Z28DJP1987's Avatar
Get the std rear LCA's from Spohn Performance, you can't go wrong with this type.
Old Nov 6, 2002 | 10:19 PM
MdFormula350's Avatar
i also had the lakewoods on my 1988 formula 350, they put an end to wheel hop!
their about 85 bucks, poly bushings with greese fittings..
Old Nov 7, 2002 | 12:28 AM
z28_dave's Avatar
From: tokyo - where the girls are pretty and the cars are fast
lakewoods are an excellent deal
Old Nov 7, 2002 | 08:31 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Lakewoods. Best deal around. Made in Ohio, too.
Old Nov 7, 2002 | 11:39 AM
Garett92Z's Avatar
where is the cheapest place to purchase lakewoods?
thanks guys.
Old Nov 7, 2002 | 02:24 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Jeg's or Summit, looking at $80 I think.
I saw a set on ebay last week and the idiot listed them as "sway bars". They went for $50 or so.
I have BMR pieces and they are very good. They really got rid of any wheel hop I had. I got mine on a GP for around $85.
Ed
Old Nov 7, 2002 | 08:27 PM
chevy8ford's Avatar
Car: 88 Firebird
I bought the edelbrocks which have grease zerks, and are boxed on the whole length not just the middle like the lakewoods, they are more expensive however. I'm not sure, but they look exactly like my friends hotchkis, and he payed more for them. I like them though and don't have have any problems, i also bought an adjustable panhard from hotchkis, but edelbrock makes a non adjustable which is cheaper, but the same design, just without adjustment.
Old Nov 7, 2002 | 09:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Huh?
My Lakewoods are a piece of square tubing with a short section of pipe welded to each end for the bushing...
Old Nov 8, 2002 | 12:51 AM
chevy8ford's Avatar
Car: 88 Firebird
This is what i mean, the edelbrocks are boxed all the way around the end, whereas the lakewoods are boxed tubes with "pipe" welded onto the end. These are just a little beefier then the lakewoods that's all.
Old Nov 8, 2002 | 06:21 AM
ebmiller88's Avatar
Here's my BMRs:
Attached Thumbnails Which LCAs-another-view-new-parts
Old Nov 8, 2002 | 09:27 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Maybe there's 2 different Lakewood products...
Mine are square tubing with pieces of pipe welded to the ends. Look at the pic, they're as plain as day. They're not stock type sheet-metal crap ones. They're not "boxed" anything, they're square tubing. They are nothing even remotely like those Edlecrap ones; they're just like the BMRs, except they're square tubing instead of round tubing. The tubing is even about the same size.
Don't buy any kind of "boxed" ones. And don't spend more than you have to in order to get the level of product you want.
Old Nov 8, 2002 | 09:37 AM
chevy8ford's Avatar
Car: 88 Firebird
Not for nothin' but, i didn't spend any more for the level of product i want, and i don't see why you would be so against boxed arms? Anyway, to each their own, i wasn't trying to "convert" anyone away from lakewood, but i noticed that everyone was saying lakewood and i wanted to share my positive experience with edelbrock. Also, the edelbrocks are also square tubing, i used boxed as a synonym.
Old Nov 8, 2002 | 09:39 AM
JERRYWHO's Avatar
If you want the best look at Global west new (QUIET-RIDE) bearing type Rear Tubular Control Arms.
The web site link is http://www.globalwest.net/THE%20LATE...BAL%20WEST.htm
Jerry
Old Nov 8, 2002 | 10:09 AM
aklaim's Avatar
[QUOTE]Originally posted by JERRYWHO
[B]If you want the best look at Global west new (QUIET-RIDE) bearing type Rear Tubular Control Arms.
The web site link is http://www.globalwest.net/THE%20LATE...BAL%20WEST.htm [QUOTE]
Too bad you cant actually see them. There's no link for them...
Old Nov 8, 2002 | 01:29 PM
9-FIREBIRD-2's Avatar
ebmiller88
where do you get the bmr's from, and is your panhard ajustable or non?
Old Nov 8, 2002 | 01:50 PM
ebmiller88's Avatar
I got the BMR stuff from Chris at Nashville Speed(www.nashvillespeed.com) which is now out of business, unfortunately. He had great prices and service, but not anymore....the woes of personal business I guess. He does still have the site up with a COOL link to a C4 Corvette brake upgrade for 4th gen cars. I'll refer to this when I (eventually) get that '00 SS 6-speed car I want.
Back to topic Q:
The panhard is adjustable since I lowered the car. On a side note, I also installed an adj. panhard (also BMR) on my '91 RS because the rearend was not centered under the car which is at factory ride height. Proof that sometimes you need the adjustable stuff anyway.
Ed
Old Nov 8, 2002 | 02:03 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
Originally posted by 9-FIREBIRD-2
ebmiller88
You can order them from ThunderRacing (banner @ top of page).
Jonathan...
Old Nov 8, 2002 | 02:12 PM
Thanks, I found them there for $109.95. Now I saw poly/poly/ And poly/rubber. what is that????
I know they are refering to the bushings, but is that a compound mix?
Old Nov 8, 2002 | 02:37 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
poly/poly means poly bushings on both ends of the LCA & the poly/rubber means poly on one end & rubber on the other end of the LCA.
Old Nov 9, 2002 | 06:19 AM
That was kinda what I had thought the answer would be. Now why would you want to mix the bushings like that? poly/poly is way better than rubber/rubber or poly/rubber right?
Old Nov 9, 2002 | 03:59 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Spohn poly/rod end adj LCAs.
Old Nov 11, 2002 | 10:47 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
You can also get BMR stuff from bmr here is there sight.
http://www.bmrfabrication.com/
Old Nov 12, 2002 | 05:54 AM
Thanks for the link.:hail:
Jorlain
Oct 8, 2015 01:57 AM
Americanmouse
Sep 7, 2015 12:10 PM
zayne0
Aug 24, 2015 07:22 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
NBrehm
Aug 5, 2015 07:57 PM
