E-Brake
Old Nov 12, 2002 | 04:09 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
E-Brake
My E-Brake stopped working.
It still works but faintly.
I can pull it all the way and my tires wont lock. It will just slow the car down SLOWLY.
Any ideas?
Old Nov 12, 2002 | 04:26 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
You're in luck. All you've gotta do is crawl under the car and tighten the adjuster. It's located just above the driveshaft mid-way. It will have the cable coming from the brake handle to a "T" bracket with a threaded rod in it (where you adjust it) and then the cables going to each of your rear brakes. Easy as pie.
Later models (89 or 90 and up) have a "self adjuster" supposedly located at the handle under the consol. I'm out to find it this weekend and see where my problems are.
Old Nov 12, 2002 | 04:40 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
yup what 1MEAN92RS is true all you gotta do is go under the car and adjust it. Everything should be all good after that.
Old Nov 12, 2002 | 10:16 PM
Yeah now I just need to browow a jack, I'll try to get one from my Grandpa.
Is there a Way I can Adjust it so I dont have to pull the e-brake back so far?
When it was 'working' I had to pull it back like to a 70Degree Angle. IS that right? Can I make it 35 or less somehow?
Now reason its just... winter! lol
Old Nov 12, 2002 | 11:22 PM
1MEAN92RS's Avatar
Engine: LO3
The more you tighten the e-brake adjuster the less you will have to pull the lever back to set it.
Old Nov 13, 2002 | 09:18 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Could this auto-adjuster thing be the reason why on my '91 my e-brake doesn't work on the first try but after I pull it once or twice it does?
Old Nov 13, 2002 | 10:34 AM
REVLIMIT's Avatar
Engine: Built L98
are you talking about when you pull the ebrake and the thing just pops up and does nothing. Like it just flies up not even tightening the ebrake. if so then yes taht is caused by the ebrake system. It was one of the flaws of the self adjusting style.
Old Nov 13, 2002 | 11:09 AM
1MEAN92RS's Avatar
Engine: LO3
See this thread I started a while back...
https://www.thirdgen.org/techbb2/sho...hreadid=124049
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
jawzforlife1
Apr 25, 2002 03:36 PM
The Dirty Bird!
Apr 1, 2002 02:36 PM
stuart69427
Feb 22, 2002 08:38 PM
88transam5.0
Dec 19, 2001 06:58 PM
