Front end rebuild confusion
Old Nov 14, 2002 | 04:08 PM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
I need some help here guys, i was searching the boards looking for the most complete front end rebuild kit. The more i looked the more confused i got.
Can someone tell me what kit is the most complete, and what i will need besides the kit?
Thank you very much
Old Nov 14, 2002 | 04:28 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i don't know about a kit but i've just about rebuilt mine. you need inner and outer tie rods for both sides and the adjuster sleeves. idler arm , you can replace the centerlink, control arm bushings and ball joints. then you'll need to get it aligned.i havn't done the ball joints yet, probably this winter, then i'll be replacing the springs too.
Old Nov 14, 2002 | 04:34 PM
9D1BURD's Avatar
Car: 1997 Z28
would i want to change any bushings then?
Old Nov 14, 2002 | 04:38 PM
craig's Avatar
Car: 86 camaro
the lower control arm has bushings in it. i plan to replace the ball joints , bushing , and springs at the same time.PST has a kit on the back of carcraft and chevy hi perf. i bought allot of my stuff off ebay and saved quite abit.
Old Nov 14, 2002 | 05:03 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
www.performancesuspension.com
I bought their front end rebuild kit for my '92 RS along w/ the centerlink. I did a lot of research before I bought anything and I came to the conclusion that PSC has the most complete kit. Their kit includes all federal mogul parts & energy suspension bushings.
Spohn also has a front end rebuild kit (link @ top of page). I would compare prices and go w/ the less expensive one.
Old Nov 15, 2002 | 05:00 PM
aklaim's Avatar
Js92RS...Are you happy with the kit you bought? Imean have you installed it yet and are happy with the results? I think I'm goin to order this kit but not sure yet, I kinda want to hear some feedback from people that have installed it.
Old Nov 15, 2002 | 05:24 PM
CrazyHawaiian's Avatar
Car: too many ...
And dont forget, if your car is lowered and you plan to do a front end rebuild, now would be the time to look into a bumpsteer kit. Fix that suspension geometry!
Old Nov 15, 2002 | 05:31 PM
vjo90RS8's Avatar
Car: 2002 Z28
Spohn sells a Moog rebuild kit, add some poly A-arm bushings (Prothane or ES) and you have a front end that will likely outlive the car.
Old Nov 15, 2002 | 05:32 PM
vjo90RS8's Avatar
Car: 2002 Z28
here are the links
http://www.spohn.net/index.cfm?fusea...&productid=115
http://www.spohn.net/index.cfm?fusea...t&productid=93
Old Nov 15, 2002 | 05:36 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Yes, I am very happy w/ this kit. I would highly recomend this kit to anyone that still has the stock front end suspension. If you do order this kit, make sure that you tell them the size of your front sway bar because if you dont they will just assume that you have the 32mm sway bar bushings. I had to send the 32mm back because my RS came w/ 34mm front sway bars.
Old Nov 15, 2002 | 05:50 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
You will end up paying more for Spohns kit that has the same items/brands as the kit from PSC, trust me I did the math. With the PSC kit ($279.95) you get everything that you need except for the centerlink but you can get it through them for an additional $65.00. With Spohns kit ($342.60) the bushings, (end links to name a few) are not included. I just dont like to spend extra if I dont have to, I work too hard for my $$.
Old Nov 15, 2002 | 06:15 PM
vjo90RS8's Avatar
Car: 2002 Z28
true, but if you want to "best" front end rebuild, Moog is the way to go
Old Nov 15, 2002 | 07:45 PM
CaysE's Avatar
I was under the impression that the PSC kit used Moog components. I could be wrong though. In terms of "completeness," I'd say that Spohn is the answer. They sell two kits for the front end:
Prothane poly bushings:
Rear Lower Control Arm Bushings
Panhard Bar Bushings
Ball Joint Boots
Torque Arm Bushing
Tie Rod Boots
Front Sway Bar End Links
Front Sway Bar Bushings
Rear Sway Bar End Links
Rear Sway Bar Bushings
Transmission Mount
Front Control Arm Bushings
Moog front-end hardware:
Moog Centerlink
Moog Idler Arm
Moog Inner Tie Rod Ends (Qty. 2)
Moog Outter Tie Rod Ends (Qty. 2)
Moog Lower Ball Joints (Qty. 2)
Moog Adjusting Sleeves (Qty. 2)
The combined price is more than PSC, but considering how complete and meticulously assembled the kits are from Spohn, I'd go with them. The Prothane kit includes almost all of the bushings you'll need for the entire car, so it's an extra bonus. All I can see missing in the kit is motor mounts. EVERYone has nothing but praises after dealing with Spohn and getting their parts installed, so that's my suggestion.
http://www.spohn.net/index.cfm?fusea...&productid=106
http://www.spohn.net/index.cfm?fusea...&productid=115 (no need for the additional parts at the bottom of this page if you get the poly kit.)
Old Nov 18, 2002 | 10:44 AM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
that is what comes w/ the PSC kit.
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
