Swapping drum for disc
Old Nov 22, 2002 | 11:47 AM
justadba's Avatar
Car: 88 IROC convertible, 88 Sport Convertible---both RED
Engine: 350 TPI in the IROC, 305 TBI in the Sport
Transmission: 700R4 in both
Have an '88 IROC that has drum brakes on the rear...
How difficult is it to swap them out for disc...current rear end is the stock that came with the car.
Can the parts be picked up at parts stores or do you have to locate a 3rd gen at a bone yard to get the necessary parts...
TIA
Old Nov 25, 2002 | 07:24 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
HI there. I would suggest you try a search on this topic. This same question gets asked very often, infact there is another topic that is the same on here right now.https://www.thirdgen.org/techbb2/sho...hreadid=145694
Again...Try the search option, this should tell you everything you need to know.
Keiran
Old Nov 26, 2002 | 08:50 AM
MdFormula350's Avatar
if your rear end is not posi and has a bad gear ratio, i would suggest to get a rear that has posi with a better ratio and disk brakes!
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
