Is it feasable to replace part of a brake line
Old Nov 23, 2002 | 02:47 AM
Momar's Avatar
I was under the car re-installing the tranny, and I noticed that my brake line to the rear of the car is crushed by the tranny crossmember like it got stuck between the fram and crossmemer at some point. Well, I was wondering if I could just use those little pressure fittings or whatever they are called and put a new little piece of line in there, or if I am going to need to replace it clear from the pv to the rear end?
Ben
Old Nov 23, 2002 | 03:36 AM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Yes.
The pipe will need flaring though. There are tools available that will flare steel pipes in situ.
Andy.
Old Nov 23, 2002 | 07:27 AM
ede's Avatar
ede
or you could use a compression union and not need flares. i'd just replace the whole line, leave the old line where it is and run a new piece.
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
1nastygta
Aug 8, 2015 07:38 PM
Leggman1
Aug 6, 2015 04:15 AM
