Front end problem???
Old Nov 28, 2002 | 07:14 PM
1991Formula350's Avatar
Car: 1992 Formula
Transmission: auto stock
Axle/Gears: 3:42
I seem to have a big problem with the front end of my 1991 Firebird Formula. When I seem to hit the brakes at about 50 kind of hard the front end shakes really bad, the front tires and steering wheel shake. I dont want to get robbed by a mechaic so I am asking the F-body know hows' here. Please help, the regular guy who does my oil lifted her a while back and said the front end looked solid, but he is a Jap car guy, knows crap from Formula to standard cheap versions. Andy
Old Dec 1, 2002 | 11:22 PM
MdFormula350's Avatar
shuttering in the front could be caused by the front rotors/pads..
when the last time you did a brake check/change.
Old Dec 19, 2002 | 08:42 PM
Car: 1992 Formula
Axle/Gears: 3:42
thanks for the help, It was the rotor, had them both cut and now no more rattle. Only problem is slight pull to the right when braking a little hard, front end wheels aligned already. Andy
Old Dec 20, 2002 | 08:22 AM
no problem. try bleeding the brakes if that doesnt work then you may need to replace the brake hose(s).
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
bellez77
Sep 5, 2015 08:39 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
