diff. in weight transfer after front sway bar removal?
Old Nov 29, 2002 | 03:32 PM
Fast3rdGen's Avatar
how much does this actually help? somebody told me that almost stock 4th gen A4 cars were almost pulling the tires with the front swaybars un hooked and on sticky tires. does it help that much?
Old Dec 1, 2002 | 02:23 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I think it helps a lot. I also have moved the battery to the trunk and have a fiberglass hood. So the extra weight out of the front just seems to get the front to lift higher w/o spinning.
I've launch on the juice at the track puttin down 551tq at the wheels. That realy gets the car jumpin.
Old Dec 1, 2002 | 11:33 PM
MdFormula350's Avatar
more weight transfer in the rear the more chance for better traction..
Old Dec 5, 2002 | 01:19 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
If you look at the new GM High Tech Performance there is a 4th gen running high 12's with no sway bar and you can see air under the driver side tire.
Old Dec 5, 2002 | 02:54 PM
David 91RS/Z28's Avatar
I've had good success from removing the swaybar. The car lifts up a bit higher and quicker to get the weight transferred. Give it a shot, can't hurt for sure. Just don't try running down those sharp curves anymore.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
3rdgenparts
Aug 8, 2015 07:09 PM
