Brake light coming on
Old Dec 4, 2002 | 03:25 PM
JohnS's Avatar
Car: 2004 Nissan 350Z
Engine: 3.5 V6
Transmission: 5 speed auto
It comes on after I've been driving for about a 1/2 hour,but the pedal feels the same,a little mushy.I do have a very small leak in the master cylinder,but the fluid level is ok.Will that cause the light to come on?Thanks
Old Dec 4, 2002 | 04:08 PM
ede's Avatar
ede
there is a preasure differance between the front and rear brakes and the idiot light, or the system is picking up on it and setting the light, most likely. look for a leak, if you can't find one you may have a internal leak in the master cylinder seals. there is also a small chance the light is set with no leak.
Old Dec 5, 2002 | 12:46 AM
MdFormula350's Avatar
sounds like you need to get the leak fixed.. and work from there..
Old Dec 5, 2002 | 01:41 AM
JohnS's Avatar
Engine: 3.5 V6
How much does a master cylinder cost?
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
