lowering my car
Old Dec 10, 2002 | 11:28 AM
badazz84camaro's Avatar
lowering my car
i have the eibach prokit for my 1984 camaro, what do i need suspension wise to lower it properly.
Old Dec 10, 2002 | 01:01 PM
aklaim's Avatar
LCA reloaction brackets and a bump steer kit.
Old Dec 10, 2002 | 01:04 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Ajd. Panhard
Old Dec 10, 2002 | 05:46 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You just need and adj. panhard bar and lower control arm relocation brackets. Thats it. Bump steer kits are not necessary and I have 17x9's up front with the Eibach sportlines (lower than pro-kit) without any rubbing at all.
Old Dec 10, 2002 | 05:48 PM
aklaim's Avatar
He said lower it properly. Thats why i recomended the bump steer kit. The front geometry will change when lowering the car, so in order to restore it the bump steer kit is needed. It has nothing to with tire rub.
Old Dec 10, 2002 | 10:06 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Where sells bump steer kits?
Old Dec 10, 2002 | 10:55 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Baer sells bump steer kits:
http://www.baer.com/Showcase/BaerTracker.aspx
-Rich-
Old Dec 11, 2002 | 05:49 AM
MdFormula350's Avatar
bump steer kits interesting! never knew about that kit..
Old Dec 11, 2002 | 07:05 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I knew about the kit but didn't know that the front geometry changed at all. I knew the rear did but not the front. You learn something new every day. Well than I geuss it wouldn't hurt to have but if he is a poor mans modder, like all thirdgeners are, he could probably save that for later
Old Dec 11, 2002 | 12:48 PM
laiky's Avatar
if anybody is interested i have Adjustable panhardrods for sale ( herb adams)
Old Dec 12, 2002 | 01:50 AM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
This may sound retarded but what exactly does the bump steer kit do?
Old Dec 12, 2002 | 01:33 PM
CrazyHawaiian's Avatar
Car: too many ...
The bump steer kit allows you to adjust the angle of your tie rods (outer I think). The adjustment is needed when the height of the car is changed (aka lowered) and the suspension geometry is thrown off. This can cause the unwanted effect of bump steer when you are roadracing. With the bump steer kit, you can correct the geometry of your tie rods and avoid bump steer. To read more about bump steer click here:
http://www.racerpartswholesale.com/longtech3.htm
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
