z28 vs RS steering
Old Dec 10, 2002 | 01:39 PM
jbcmyk's Avatar
z28 vs RS steering
is there any difference between 1992 z28 and 1992 RS steering boxes? is the z28 box a faster ratio ? it should fit an rs.
Old Dec 10, 2002 | 04:11 PM
aklaim's Avatar
From what I know in 92 there was no difference. And yes it will fit. I warn you now tho, its a fairly simple swap but getting the pitman arm off is a bitc*.
Old Dec 10, 2002 | 04:26 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Ust this if you do have to do the job and remove the Pitman Arm. They are tight but will move!
http://www.etoolcart.com/product.asp?3=337
Andy.
Old Dec 10, 2002 | 04:50 PM
aklaim's Avatar
I actually used that and had no luck. I also used the fork which didnt do anything as well. Maybe you'll have better results than i did.
Old Dec 11, 2002 | 12:29 PM
jbcmyk's Avatar
steering gear
so the rs and z28 had the same ratios?
would it be better to just buy a new pitman arm rather then rent a tool?
thanks john
Old Dec 11, 2002 | 12:33 PM
aklaim's Avatar
The pitman arm is conects the steering box to the center link.....you have to get the pitman arm off to get the steering box off. just remove the the pitman arm from the centerlink first. Then remove the steering box. The pitman arm doesnt wear out on our cars, so replacing it isnt necessary.
And i do believe the ratio in 92 was the same for both the RS and Z28
Old Dec 11, 2002 | 03:03 PM
Car: 91 camaro rs
I have never failed to remove one yet, but oil the threads on the puller very well and use a breaker bar to tighten it down. Go steady, a slow pull at a time! I also wrap a shop rag round the tool to hold in shrapnel just in case it goes bang!
Persevere, it will go eventually.
Andy.
Old Dec 12, 2002 | 02:31 PM
MdFormula350's Avatar
woopsey, i just saw that in a search i ran!!
Old Dec 12, 2002 | 02:33 PM
aklaim's Avatar
The Z has absolutely nothing to do with it. Its in the casting number.....
Old Dec 12, 2002 | 02:39 PM
caught that one quick
https://www.thirdgen.org/techbb2/sho...uick+ratio+box
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Ian Irvine
Sep 4, 2015 08:08 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
