Sportline Opinions
Old Dec 13, 2002 | 03:20 PM
whitez406's Avatar
Sportline Opinions
Iam getting Eibach Sportline springs for my car. I was wondering what everyone that HAS or HAD these springs thinks of them. To low, stiff, etc. If can throw some pics in to. Thanks Guys:lala:
Old Dec 13, 2002 | 04:05 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Well the sportline is just as stiff as the prokit springs. The only problem with it that I see is that its lower. The lower you go the more you screw up your front and rear suspension geometry. So it counts what your going for. More performance? or more for looks?
Old Dec 13, 2002 | 04:25 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Never had a problem with the.....luv'em!
Old Dec 13, 2002 | 04:36 PM
Troy 85Z's Avatar
Car: 85 Z
Engine: Edelbrock Injected 350
Axle/Gears: 3:42 LS1 Posi
I'm really glad I went with the sportlines over the prokit. They ride better than my stock Z28 springs but didn't lower the car as much as advertised, probably because the factory springs were sagging. As far as handling goes, the prokit may be better for all out handling, but the sportlines are still better than stock. I'm running 275/40/17 all around without any problems. I think you'll be happy which ever way you go. Good luck.
Old Dec 13, 2002 | 05:29 PM
whitez406's Avatar
Im going wiht the sportlines. Im going 60% handling and 40% looks. Im running 16" irocs powdercoated black wiht a 245/50-16. Do theymake a 245/45 or 40-16
Old Dec 14, 2002 | 12:01 AM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
yes kumho makes a 245-45-16, i have four of them on my iroc. i bought the iroc and it was slammed to the ground in the front, and the tires tuck in the fenderwells. im not sure what drop they went with or how they did it, but it is extremely stiff, just the way i like it. ill post pictures when i can get some nice sunny weather. im wondering how much rubber i can fit in the rear with the stock iroc 16's. 275, 285?
Old Jan 2, 2003 | 08:17 PM
CaysE's Avatar
Does anyone have pictures of the Sportlines on a Sport Coupe (no ground effects)? I really want to see what they would look like. Any clearance problems with aftermarket exhaust or SFCs?
Old Jan 4, 2003 | 10:36 PM
CaysE's Avatar
TTT
Old Jan 4, 2003 | 11:59 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Here is mine with sportlines... I put myself on the "love em" list.
Old Jan 5, 2003 | 12:05 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
+1 luv em.
-Schultzy
Old Jan 5, 2003 | 05:08 PM
BOTTLEDZ28's Avatar
Transmission: A4
I have the pro kit on mine now and I want it lower. he problem is that my exhaust will definitly drag over speed bumps. For some reason, my porkit springs made my last z sit lower then the one I have now and there the same springs. Just swaped them out. Ive been thinking of cutting my stock springs but my chiropractor keeps saying no
Old Jan 5, 2003 | 06:09 PM
raggedout91RS's Avatar
Car: '84 Z28
Engine: Goodwrench 350
Axle/Gears: good guess
Hey RU-Qwik, your car sits just like I want mine to. How much do those sportlines cost?
Old Jan 5, 2003 | 07:37 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
I bought my springs about 6 years ago, so the current price is most likely differant now( I paid 245.00 ). Check Summit or Jegs, they both carry them.
Old Jan 5, 2003 | 09:27 PM
Car: 1989 GTA
$208 @ tirerack.com
Old Jan 6, 2003 | 06:38 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I also have the Sportlines and I love them. I have a few recomendations though.
1. You car will ride rough but the handling is awesome
2. Replace your spring isolators, (mine rattle pretty bad)
3. You will need at the very least relocation brackets and an adjustable panhard bar for the rear. If not your rear end will stick out to far to one side and the car will lose a tremendous amount of traction.
Old Jan 6, 2003 | 07:05 PM
ctandc's Avatar
So the Eibach springs definitely ride rougher than the stock IROC springs?
Me thinks I'll be using some Moog WS6 spec springs and maybe cut half a coil or so.....
Old Jan 6, 2003 | 11:01 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
I had the F-41 suspension package before I swapped to Koni / Eibach , I personally think it rides better now, just my opinion.
Old Jan 9, 2003 | 08:02 PM
CaysE's Avatar
Anyone have pictures on a Sport Coupe (without ground effects)?
Old Jan 13, 2003 | 06:01 PM
CaysE's Avatar
TTT :[
Old Jan 16, 2003 | 10:25 PM
CaysE's Avatar
TTT
NOBODY has Sportlines on a sport coupe without ground effects?
Old Jan 17, 2003 | 07:59 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I have them on my Formula if that will help. I haven't had any steering geometry problems with them at all. I did get the adjustable panhard bar and LCA relocater brackets which helped out tremendously.
Old Jan 17, 2003 | 07:42 PM
CaysE's Avatar
That looks nice Mongoose! Have any more pics?
Old Jan 18, 2003 | 08:42 AM
Mongoose's Avatar
Car: 90 Formula
I'll have to check. Most of my old pics were lost.
Old Mar 26, 2003 | 10:23 PM
CaysE's Avatar
Reviving this old post... anyone have pics of Sportlines or Pro-Kits on any Camaro WITHOUT ground effects? Post em here!
Old Mar 28, 2003 | 12:03 AM
CaysE's Avatar
TTT TTT TTT TTT TTT TTT TTT
Old Mar 28, 2003 | 09:23 PM
CaysE's Avatar
OK, since noone has any responses, let me ask a different question:
For all of those with Eibachs on their car in NJ (or anywhere else with horrendous roads), please tell me about your experiences with your Pro-Kits or Sportlines. Any horror stories or have you had generally good luck with them? Any info to help me make up my mind is appreciated.
Old Mar 29, 2003 | 05:15 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You have to go slow over speedbumps and stuff and the ride is pretty rough. You will get beat up pretty good but the performance outways the ride quality.
Old Mar 29, 2003 | 06:03 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Can someone with sportlines and stock tire diameter give measurement from the ground to the fender on a level surface?
Old Mar 29, 2003 | 06:34 PM
llvll4l2c91350's Avatar
I say go with the prokit if all you're lookin for is a mild drop. reason why i didn't go with sportlines was because from reading different posts, they can drop a car as much as 2" which would've made mine almost undriveable. my prokit dropped it 1" at the front and 1/2 at the back. i love the way it looks now. not too low and not high anymore either. the ride does seem a bit harsher but still tolerable. they are recently installed so they should drop a little more as time goes by. search for the thread "pics of my newly lowered ride" to see my pics.
Old Mar 31, 2003 | 08:48 AM
CaysE's Avatar
I'm sure I could get used to the rough ride, seeing as my old worn out suspension is rough as it is. The rear of the car sits much lower than stock due to failing parts, but I like the height of it. It looks lower than the Pro-Kits would bring it, so I'm thinking of going with the Sportlines (drop 1.6" front & 1.3" rear) and put new GM isolators on front and back (raising them back up a few tenths of an inch). This should work perfect I think.
89 Iroc Z: when I get the Sportlines (eventually) I'll still have the stock tires on it. It'll be a while, but I'll post the gap height here.
Old Apr 2, 2003 | 09:10 PM
xpimpitox's Avatar
Car: 86 IROC-Z
Engine: LG4
Transmission: 700R-4
I have Intrax which is basically a 2 in. drop. That with my 3in exhaust spells trouble. For the most part its ok but there are certain times when the poor pipes get the scrapage and im like ughhhh no! so i was thinkin of switchin em up with eibach pro-kits or sportlines. this guy at work wants 2 sell me pro-kits and kyb shocks/struts but i was thinkin of gettin sportlines cuz i like the low look but it wont be as low as my current intrax. the ridin with the intrax is pretty rough and I have gotten used to it. They handle pretty damn good. So i just wanna seea pic of pro kits on a 3rd gen with ground effects so i can decide on what 2 do when the time comes to work on my suspension which may be soon due to my exhaust scrapage (which isnt very often but still bugs the **** outta me). my 2 cents.
Old Apr 2, 2003 | 11:57 PM
iroc22's Avatar
xpimpitox do you have any pics?
Old Apr 3, 2003 | 12:29 AM
xpimpitox's Avatar
Car: 86 IROC-Z
Engine: LG4
I have this pic of my car that was on autotrader.com and i saved it before they took the ad down. I dont have a digi cam and my scanner is broken so i dont have fresh pics of my car. its a kinda blurry pic and its just how it is now minus the exhaust system. check it out here: http://members.cardomain.com/pimpin86iroc
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
