how to install LCA relocation brackets
Old Dec 27, 2002 | 01:36 PM
colonboy14's Avatar
Car: Trans Am
Ok, I know that the Spohn LCA relocation brackets just slip over the bottom of the stock bracket and weld on, but the guy that will be installing them can't understand this. I know there are some good pics floating around there, but I can't find them. So if someone could post some good pics showing how they weld on, it would be much appreciated.
Also, welding these on won't take much time, will it? It seems like a simple operation to me, but the welder thought he would have to cut things and fabricate things and all kinds of stuff, and that it would really cost me. Im no expert in the art of welding, so how long should these take to install? An hour? Maybe 2?
Old Dec 27, 2002 | 01:56 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
It is a real straight forward operation. I lined them up and bolted them in, then welded. Do one side at a time. It shouldn't take more than 1 hour for the whole job. I could probably do it in one half hour if I needed to do it again. Most of that time is taking off wheels etc. Probably 15 minutes worth of welding. No fabrication. Nothing tricky.
Here are some pics...
Hope that helps.
-Schultzy
Old Dec 27, 2002 | 02:50 PM
colonboy14's Avatar
Car: Trans Am
thanks, that's exactly what I needed.
Old Dec 28, 2002 | 03:12 PM
MdFormula350's Avatar
nice pics, it does look like a nice straight forward job..
Old Dec 28, 2002 | 08:47 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Excellent picture. I would have been asking that queston too in the future. Now its just an easy copy and paste.
thanks, Schultzy89GTA :hail:
Old Dec 29, 2002 | 12:13 AM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
I had a local muffler/welding shop install mine. It took less than an hour and only cost $50. As mentioned above, do one side at a time. No need to remove the wheels and they should ideally be MIG welded. It's a simple install.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
toronto formula
Nov 10, 2015 06:17 AM
TheExaminer
Aug 25, 2015 07:34 PM
