Brake pedal all the way to the floor before stopping!
Old Jan 4, 2003 | 01:08 AM
Vicious 88 GTA's Avatar
When I step on my brakes the pedal is really soft and goes all the way to the floor before the car starts to stop...whats up with that...do I need to bleed the brakes any ideas?....AARON
Old Jan 4, 2003 | 08:01 AM
kevinc's Avatar
Car: 1982 Z28
Bleeding is a good place to start. If the problem clears after bleeding but then returns you have a leak somewhere in the hydraulics.
While you're bleeding, look for signs of fluid leakage...wet streaks on the insides of the tires are a sure sign.
Old Jan 4, 2003 | 06:15 PM
StangKiller's Avatar
Old Jan 4, 2003 | 06:17 PM
Did you check the fluid level? If it's good, try bleeding them, if that don't help theres a good chance you need a new master cyl. and maybe calipers and or wheel cyl. And odds are if the master was good and more than a few years old when it went to the floor the seals inside passed over built up rust in the piston bores and wiped out the seals anyway.
Old Jan 4, 2003 | 10:08 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i would start by checking the fluid level
1992 Trans Am
May 10, 2023 07:19 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
