SFC installation problems???
Old Jan 14, 2003 | 03:12 PM
youngin's Avatar
I am ordering my Competition engineering SFC today and was wondering if the carpet needs to be removed for the installation of these and if there are any other minor modifications or tips to installing these. Car is in the sig.
Old Jan 14, 2003 | 05:16 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
if they are bolt in then you won't have to pull up your carpet. if you will be welding them then you need to pull the carpet away from the floor where you'll be welding so you don't burn it. if you're not planning on welding, you really should, bolt holes can elongate over time.
Old Jan 14, 2003 | 09:12 PM
sllt1776's Avatar
Car: 89 Iroc-Z
actually if they bolt in you may still have to pull up the carpet. it depends on where they bolt to. if it is to the floor board then you need to pull it up to drill the holes so they don't go thru the carpet. if that's the case leave the carpet up until they are welded also...because like you were already told the holes elongate over time and welding is much better.
rocn7roc
Sep 21, 2021 02:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fronzizzle
Aug 17, 2015 02:52 PM
TheJoeY88
Aug 13, 2015 06:51 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
