Want to remove panhard rod to haveit boxed,How hard will it be to put back on?
Old 01-16-2003, 07:41 AM
firebird305's Avatar
If i take off my panhard rod to have it boxed,will the rear end move around and make it hard to put back on? I had some problems getting my LCA's back in after haveing them boxed,So i was wondering if i'll have the same problem with the panhard bar.
Old 01-16-2003, 08:58 AM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
It shouldn't be too bad if you've got the chassis up on stands, allowing the hanging axle to move left & right. Yes, it will move around a bit - I would keep the car on stands through the whole operation. You will be able to move the axle left/right by hand or with a small pry bar no problem.
Re-installing the lower control arms is more difficult because you are working more against the springs.
Old 01-16-2003, 05:24 PM
z28redline's Avatar
Car: 1986 Camaro Z28
Engine: 305 lG4
I had my panard bar off about a week ago and it wasn't to hard to put back on. May be easier if you have a second person but if you use a pry bar it shouldn't be to hard to line the bolt holes up.
z28redline
Old 01-16-2003, 07:24 PM
MdFormula350's Avatar
yeah support the frame rails with jack stand and put a jack under the rear end and go about pulling off the panhard bar..using the jack to move it up and down, or left anf right a tad if needed.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
3rdgenparts
08-08-2015 07:09 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: Want to remove panhard rod to haveit boxed,How hard will it be to put back on?
