Custom Subframe Connecotr help
Old Jan 16, 2003 | 08:27 PM
AFast83z28's Avatar
What are the dimensions on y'alls subframe connectors? I need some pics of any SUBFRAME CONNECTORS on a car. I am going to do my own hopefully this weekend. Also...is there anything I should plan ahead for? I am doing a 9 inch rear swap in a few months, welding in a driveshaft loop, stuff like that? Need the L X W X H of the subframes..
Old Jan 17, 2003 | 06:55 AM
AFast83z28's Avatar
ttt
come on
Old Jan 17, 2003 | 07:26 AM
ede's Avatar
ede
jack your car up get under it and measure, it isn't hard and if you're smart enough to make a set you can handle getting the measurements. just go from point a to point b, it isn't hard to do.
Old Jan 17, 2003 | 07:28 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i'm with ede here, if "I" was making them, i would wnat them made to fit MY car, and not the measurments someone else took of THEIR car.
Old Jan 17, 2003 | 11:47 AM
DukeofBird's Avatar
you will most likely want to use 2"x3"x.120 wall rect tubing. and like the other people are saying, you will also want to measure your own car. there are also two spots where you can mount sfc's. out next to your rockers(which doesnt usually interfere with exhaust, or floorpans, but isnt all that strong). or more under the seats(which interferes with floorpans, exhaust, but is really strong because it actually ties front and rear subframes together). your choice. have fun
Old Jan 17, 2003 | 02:33 PM
AFast83z28's Avatar
Post a pic
I don't know exactly where they mount is the problem so if anyone would help that would be great. The reason I was asking for dimensions is how thick they are. Not neccesarily the length or width..
Old Jan 17, 2003 | 08:00 PM
ede's Avatar
ede
i used 1.5x2x.187 and 1x2x.093 as well as 3x.187 flat all a36ms
Old Jan 17, 2003 | 08:05 PM
AFast83z28's Avatar
In english
So what exactly does all that mean? and what is a36ms?
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
tmork454
Sep 29, 2015 06:33 PM
dusterbd
Sep 29, 2015 08:40 AM
