v6 lowering
Old Jan 27, 2003 | 05:48 PM
Xceleratemaro's Avatar
v6 lowering
i own a 90 camaro 3.1 v6 and i was wanting to lower the car about 1-2 in but i dont know if the v8 lowering springs will do any thing or is there a v6 kit i havent found yet? if not i also want to replace my rear sway bar bushings bc they have rotted away how hard is that and is there a big improvment?> thanks for you imput!!
Old Jan 27, 2003 | 06:23 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
as for the drop springs I dont know of any company that makes for the V6. If you use the V8 springs I dont know if it till atcually drop your car. It may even raise it. Cause the spring rate will be alot more then the V6 version.
As for the bushing its pretty easy to replace. All you gotta do is take off the rear sway bar slide off the bushings and then slide on the new ones. Pretty simple and easy. And you'll notice a difference especially if your current one is destroyed.
Old Jan 28, 2003 | 03:56 PM
thanks any one know about v6lowering????
Old Jan 28, 2003 | 11:03 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
They are out there, they just don't advertise them because the market is much smaller for v6 than v8. I'm almost positive that eibach makes a couple of types for the v6 cars. Just call summit or jegs and tell that what you need.
Old Jan 28, 2003 | 11:22 PM
AFast83z28's Avatar
Eibach makes them
I am 95% sure that Eibach makes them because I calle dabout some the other day.
Old Jan 29, 2003 | 03:53 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
I used V-8 spings in mine. No problems with them.
I'm also using drop spindles too.
Old Jan 29, 2003 | 11:33 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
That's where you're getting the drop from. But from what I've heard the spindles aren't available anymore. There's always the option of cutting your springs, although it's usually not a good idea.
My brother just told me that Les Schaub will lower a v6 for about $500. It includes springs, installation, and re-alignment. So if you have one near you, check there. At the very least they could tell you who they use.
Old Feb 1, 2003 | 10:04 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
I just found these while I was looking around online. So at least you know that there are some out there. http://shop.store.yahoo.com/streetbe...vcamv682s.html
Old Feb 1, 2003 | 10:56 PM
You are the f*cking man hell yea thanks for your help
Old Feb 1, 2003 | 11:05 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Glad I could help. I just want to remind you though that I've never bought anything from this store. So I'd call and make sure they're a legitimate brand, like eibach, before you buy them. Best of luck.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
MrPackstin
Oct 25, 2017 08:09 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
92projectcamaro
Sep 29, 2015 07:07 PM
