how long should it take a shop to install lca's?
Old Feb 1, 2003 | 11:49 AM
89IROCZZ4's Avatar
I just got back from a shop that said it was going to take them about 1 1/2 hours to install my lca's for a grand total of $75. Does this sound right???
Old Feb 1, 2003 | 12:20 PM
Z28DJP1987's Avatar
Little long on time, but the price sounds about right. They will work to get the mounting bolts off.
Old Feb 1, 2003 | 02:41 PM
MdFormula350's Avatar
it took me an hour for both sides, and it was free i did it...
air tools helped alot...
Old Feb 2, 2003 | 12:26 AM
sllt1776's Avatar
Car: 89 Iroc-Z
yea do it your self. even without air tools. as long as the bolt aren't rusted. give them a squirt of lube the day before you start to get it worked in. it should only take and hour or 2 alone. do one side at a time though.
Old Feb 2, 2003 | 12:40 AM
rezinn's Avatar
You can buy some ramps for $20 and do it yourself. It shouldn't take more than an hour. I did my LCAs and panhard bar in a little over an hour and a half last year. You'll need to hold the nut on the side of each bolt and then use a ratchet to get the bolt out. I forget what size they are, but they're pretty big and they're metric. You could buy all the tools you could possibly use back there for $75.
Old Feb 2, 2003 | 12:53 AM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Please disregard- I thought you meant relocation brackets!
If these are weld-in's and you're not a welder, I'd go for their
offer.
I welded mine in (Spohn) with a buddies mig unit, and it took a while to do it right (about 3 hours), total. If they are only bolt in's, you can probably do it for less yourself, though I agree with previous posts that gettting the bolts out is no picnic. I had to physically destroy my stock trailing arms to remove them. I replaced them with Hotchkis units.
That is the results of Chicago winters.
In addition, I replaced my trans mount, torque arm mount and stiffened my torque arm. This totally eliminated the bunny hop I had been experiencing.
Best-
S-D
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
TheExaminer
Aug 25, 2015 07:34 PM
NBrehm
Aug 5, 2015 07:57 PM
