front end suspension options??
Old Feb 15, 2003 | 09:17 PM
trigger GTA's Avatar
Car: 92 TA vert
i am looking for options for the front end of my project car. seeing as how it is totaly shot and will need to br replaced. its time to look for options on what i can do.
right now i am willing to look at every thing out there and dont mind if major work will need to be done.
as you can see from the pic the lower control arm must be replaced. along with other stuff
never seen one that bad before
Old Feb 15, 2003 | 09:29 PM
CrazyHawaiian's Avatar
Car: too many ...
Yeah that does look really bad. Before you start spending money on parts I would take everything apart and see if the mounting points and frame pieces themselves are still good. It would be a bad experience to install all these great front end parts, but then have the car fail later because of rust weakened frame area's or mounting areas. Off the top of my head here are some chassis/steering things that you can buy for the front end:
Front End Rebuild Kit from Spohn (around $350) includes:
- Moog Centerlink
- Moog Idler Arm
- Moog Inner Tie Rod Ends (Qty. 2)
- Moog Outter Tie Rod Ends (Qty. 2)
- Moog Lower Ball Joints (Qty. 2)
- Moog Adjusting Sleeves (Qty. 2)
Tubular K-Member from PA Racing (around $400 from Thunder Racing)
Tubular A-Arms from PARacing (around $300 from same place)
From the look of it the car probably needs new springs and struts too. It would also be a good idea to redo all the bushings while you're at it.
Old Feb 15, 2003 | 09:37 PM
Car: 92 TA vert
i have not got the car apart. but will be sure that it is a solid base for a project. from what i can see so far it seen to only be the suspension parts that are bad. the sub frame seem to be good.
i will know for sure when i get it all apart.
i am even open to the idea of a vette front end or something like fatel 88 did with the forthgen (sub frame and suspention.)
i am looking to build a car that is not what you would normaly see.
i am also looking into a IRS aswell. but thats for another post
Old Feb 15, 2003 | 10:08 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Damn, looks like your car has been sitting in the ocean or something. But yeah, I agree that on something that looks that rusted, you should inspect the rest of the subframe to make sure it's ok. Especially around the steering box, it's been known to crack around the mount holes on the frame. If everything checks out ok, then the front end rebuild is mandatory and should be all you need. The PA Racing stuff is nice, but not necessary. You can pull a K member and A arms off a junk yard 3rd gen. But if you're going through the trouble of replacing a K member then you might as well go aftermarket.
Old Feb 16, 2003 | 01:08 AM
MdFormula350's Avatar
yeah make sure you check the rest carefully you want a nice solid car to work with.
that is some hefty rust....
Old Feb 17, 2003 | 09:21 PM
Car: 92 TA vert
ok can we get past the rust for a minute and lets assume the rest is ok and usable.
i still need some options for what i could do?????
PS i dont want a stock rebuild. i am looking for somthing much better.
Old Apr 4, 2003 | 11:54 PM
89LT1Formula's Avatar
i gotta agree with what CrazyHawaiian said... everything he listed is more or less the best around. That's far from a stock rebuild and will be a nice setup when done..
Old Apr 5, 2003 | 12:43 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Damn, I saw that wreck while diving in the ocean. Bet if you look close enough you'll find a rock scallop or two.
Old Apr 5, 2003 | 02:01 AM
Kandied91z's Avatar
what else would you want to do...........either go with new a-arms or tubular.
then decide wether you want stock spring, coilover, or airbag.
Old Apr 5, 2003 | 07:41 AM
Car: 92 TA vert
ok i have had the time to tare the car down saome and its only the suspesion that is rusted real bad. so i will be going ahead with this car and the rebuild.
as for what i had in mind was or things that i am looking at are...
tubular k member
upgread everything in the front
vette front end suspesion
IRS
full frame
4th gen sub frame like fatel 88
they are all things that i am looking at doing and what it would take to do it. right now nothing is out of the question. and i am willing to look into any ideas.
goals for the car are
1 handels very well. i would like to pull 1g in the corners.
2 somthing when you look at it you go OMG
thanks scott
Old Apr 5, 2003 | 09:04 AM
Kandied91z's Avatar
i'm not sure there is anything that really makes people go omg without doing a one off custom job using an entirely different setup..........
good luck with it.
Old Apr 5, 2003 | 10:42 AM
Car: 92 TA vert
that is what i am looking at doing. some kind of "one of" or not very comon set up
now any ideas
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
Vintageracer
Jan 10, 2020 05:33 PM
bellez77
Sep 5, 2015 08:39 PM
