Aluminum Drums?
Old Feb 19, 2003 | 09:56 PM
1982chevycamaroz28's Avatar
Aluminum Drums?
Okay since its been slow at work i decided to look up parts and prices and was lookin for alumin. drums for my car. the only thing we carry are iron drums that replace the o.e. alumn. ones and i was wounderin if anyone on here has found the alumn. drum in a pepboys, autozone, struass or any parts store? becuz i wanna get the alumn. ones becuz well there lighter which will help let the wheels turn better. but if anyone has gotten the alumn. ones from pepboys let me know and see if ya can get me the part number. i work there and so far all we got are iron drums to replace them with. thanx.
Old Feb 19, 2003 | 10:56 PM
25THRSS's Avatar
Re: Aluminum Drums?
only place ive seen them is at the dealer or gm parts direct. The dealer wanted about $200 a piece if i remember correctly brand new. you could prolly find a good set used on ebay for way cheaper
Old Feb 19, 2003 | 11:18 PM
patrickm00's Avatar
geez, you could probably make them on a lathe from a giant block of aluminum cheaper than $200 apiece...
(yes, i know, that is assuming you have access to a lathe or other machine tools. but still, $200 is ridiculous. for $400 in drums, i'd say spend $800 and go for a disc-rear conversion)
Old Feb 20, 2003 | 12:03 AM
SuperchargedRS's Avatar
Car: Camaro of course
I have been building a 26' Ford speedster on paper and this is what i found for brakes (kinda like Camaro drums I think)
http://www.kanter.com/drumroto.html#BUICK
If you one could get the Aumin. Buick finned rotors than that would be the next best thing to discs.
Old Feb 20, 2003 | 02:39 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I just got Al drums from a junk yard. Minimal cost. Had to get them turned though.
Old Feb 22, 2003 | 09:21 PM
iroc22's Avatar
No aftermarket companies bother manufacturing aluminum drums because most thirdgen's came with iron drums. Most people will want to replace to factory original specs and the drums would also cost more to manufactur than regular iron.
Old Feb 23, 2003 | 06:55 AM
12secondv6's Avatar
Any chance would you guys know if they would fit a 4th gen?
I was told by a local f body guy that I could ditch my 4th gen iron drums for a 3rd gen aluminum drum.
He said it was close to 10 pounds of rotating mass removed.
I have a 97 v6 bird
Old Feb 23, 2003 | 07:01 PM
hey james ill try and find that one out for u tomarrow. ill look on the computers at work to see if they are the same size drums and whatnot and if so then all should be good but ill look into that.
Old Feb 27, 2003 | 01:52 AM
12secondv6's Avatar
Thanks!!
Old Mar 31, 2003 | 02:36 AM
JPrevost's Avatar
Car: 91 Red Sled
I just finished installing aluminum drums. I like them a lot. Not all that noticable in weight savings but I'm sure it'll help with the heat and inertia. I got them through a friend a while back for $40, pads and rebuild kit was under $50 so for $90 I've got some very nice rear brakes. They work great!
Linson
Oct 24, 2025 02:00 PM
92projectcamaro
Dec 8, 2015 12:25 AM
