Eibach pro kit...exactly how low?
Old Feb 22, 2003 | 02:12 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
I'm in the market for aftermarket springs, and I hear from alot of people that KYB shocks/struts and the pro kit are great for the street. The only problem I have is that I don't want my car any lower than it is now, someplaces I have problems scraping in driveways. Can anyone with the prokit measure the distance from the ground to center of the front bumper?
Old Feb 22, 2003 | 04:01 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
About an inch. It porbably wont lower it much at all. Most of the cars have the original springs in them, they are sagged and worn out.
Old Feb 22, 2003 | 06:51 PM
MdFormula350's Avatar
exactly! thats what i here also..
Old Feb 22, 2003 | 08:28 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
about an inch? is that the drop or the measurement he was asking for? Cause if thats the measurement, MAN ! thats low...
Old Feb 23, 2003 | 12:09 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I just installed a set of Eibach pro kit springs on a customers 88 IROC, it sets about an inch lower than it did with the stock springs.... Not too low, but it is noticeable.
Old Feb 23, 2003 | 03:18 AM
vjo90RS8's Avatar
Car: 2002 Z28
i didnt notice any drop after installing my ProKit and new (thicker) GM spring isolators (replaced 145K mile springs), but i am still happy with the ride and handling quality, and i didnt really want my car lowered anyways.
Old Feb 23, 2003 | 03:40 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
How do the companies measure their "Drop", anyway? Comparing their springs against new stock springs that haven't settled yet? They -should- compare them against 100,000 mile springs.
Old Feb 23, 2003 | 09:37 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
TomP, thats why I wanted to ask someone to actually measure the distance from the ground to the front bumper, I'm not sure if the drop is in relation to new springs, or the old sagged ones. If the prokit leaves my car at about the same height, then I'll get it. If it lowers it, then I need to get moog springs or something like that. Some people with a late 80s car say they dropped an inch almost, and some with a 91 or 92 say it didn't do anything when they replaced their old springs.
Old Feb 23, 2003 | 09:29 PM
BOTTLEDZ28's Avatar
Transmission: A4
if your worried about your car dropping then just get a new set of stock springs. I have a stock set out of a 91z28 that have 30K miles on them. There yours for $60
Old Feb 24, 2003 | 08:33 AM
Apperantley not what he was looking for. One inch is not that bad, it is a noticable difference. Like I was saying though most of the springs are worn out. They are already 1/4 - 1/2 lower than the day it left the factory. The sportlines are something like 1.6" front and 1.5 in the rear. I think, they might be a single measurment drop, basiclly 1.5". That is a little to low for me. There is also the drop spindles, if you can find them, that have a drop for 2" in the front, and the cut the rear springs to be even.
Here is a shot of two inches:
http://www.iroczdesigns.com/
Old Feb 24, 2003 | 01:36 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
anyone have pics of cars with the Eibach pro kit?
Old Feb 24, 2003 | 02:33 PM
vjo90RS8's Avatar
Car: 2002 Z28
here is my Eibach Pro Kit and new GM (thicker) isolators
Old Feb 24, 2003 | 08:37 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
That looks like it's around stock ride height - maybe even higher. It sure sits higher than my 83TA with 100K on the springs.
Do you know the distance from the fender lip to the ground - I think stock is about 27 inches.
I'm installing a ProKIt and this new GM isolator business is worrying me.
Old Feb 24, 2003 | 08:43 PM
for stock hieght, before I changed my springs to DropZone they were at almost 28" rears..and my car didnt sag a bit. heres a picture before i changed them.
Old Feb 24, 2003 | 09:19 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Here are pictures of the 88 IROC that I just installed the Pro- Kit springs on....
Old Feb 24, 2003 | 09:20 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Old Feb 24, 2003 | 09:21 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Old Feb 24, 2003 | 09:22 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Old Feb 24, 2003 | 09:23 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
I did not take a tape measure with me when I went over to take these pictures... Sorry. The car is far from being too low, and it rides / handles very well.
Old Feb 24, 2003 | 09:37 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
RU -QUIK
Do know the tyre size he's got there.
Edit - so i can figuer out the wheel size - looks like it's less than a 26 inch wheel.
Thanx.
Old Feb 24, 2003 | 10:05 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
This low:
Old Feb 24, 2003 | 10:10 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Those tires are 245/50/16 BFg's .... The rubber spring isolators were not replaced, so they are a little flatter than new ones would be.
Old Feb 24, 2003 | 10:52 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
25.6 inch wheel then - same height as my 275/40/17s
I hope my old isolators aren't trashed because they're going back in.
Old Feb 25, 2003 | 11:19 AM
IROCUSUCK's Avatar
I have an 88 w/the same springs. I have 245-50-16's on there now and the car sits pretty close to the tire. Don't get me wrong,the car handles like its on rails and looks MEAN but the ride quality sux. If you don't mind shakin a few fillings loose get them.
Old Feb 25, 2003 | 11:56 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Thanks for all the replies. I'm definitely getting the pro kit. My car has stock springs and is as low as those pics are. They are definitely sagging.
Old Apr 29, 2006 | 09:53 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Before
FR: 26.5 FL: 26.5
RR: 27.75 RL: 27.75
AFTER
FR: 26.5 FL: 26.5
RR: 27.25 RL: 27.25
Old Apr 29, 2006 | 10:56 PM
Stevo's Avatar
Car: Pair of 92 Z28s
1" drop front
1/2" drop rear
= happy, cept i now have a noticeable rake with my 17s...
Old Apr 30, 2006 | 07:46 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
91 Formula 350.
Front 1 inch
Rear 3/4 inch.
Looks great.
Side note, if u can afford it get better shocks/struts, worth every penny once u experince it :-) Never thought jumping to Bilsteins would make my day but I will never go back.
While doing the suspension stuff check out the strut bearing and replace them, they always get overlooked on our cars
later
Jeremy
Old Apr 30, 2006 | 01:01 PM
Stevo's Avatar
im trying not to spend money right now, id appreciate it if you reframe from telling me anymore how nice bilsteins are....i will never have a bank account if i stay on TGO...LOL
Old Apr 30, 2006 | 06:05 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
on my old ride the height of the car
left front: 26.5
right front:26.5
left rear: 27
right rear:27.25
Old Apr 30, 2006 | 06:26 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
While i never had anything other than Bilsteins with my Eibach's I LOVE THE SETUP! I couldn't imagine going with anything different, they were worth every penny i spent on them! GET THEM, YOU WON'T REGRET IT!!!!!
F.I. 57 Belair
Aug 23, 2021 01:09 AM
db057
Apr 28, 2019 07:45 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Chiknhawk
Sep 10, 2015 08:55 AM
adelane
Sep 9, 2015 08:51 PM
