sway bar u-bolt qustion
Old Feb 24, 2003 | 09:25 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Where are you guys buying the u-bolts for the rear sway bar, I really need to reinstall mine before the season starts.
Old Feb 24, 2003 | 10:13 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I've never had to buy new ones. I just sandblast the old ones and coat them with POR-15.
Ed
Old Feb 24, 2003 | 11:39 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I think TDS might sell them.
Old Feb 25, 2003 | 01:23 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
well for the u-bolts that go around the axle, I use muffler clamps. And for the u-bolt that goes around the sway bar and mounts to the rear axle clamp, I buy them through summit. I believe energy suspension sells them separately.
hope this helps
Old Feb 25, 2003 | 06:26 AM
IHI's Avatar
IHI
Thanks guys.
Old Feb 25, 2003 | 09:40 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes I have them. I'd prefer to sell them along with the saddle & bracket though since each is plated as a set. I just got a batch back from plate yesterday. I need to reevaluate the cost since the plating cost increased.
Lon
Old Feb 25, 2003 | 11:01 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Lon,
I'd be interested in the U's and the saddle, plated. Let me know when you have an idea of price.
JamesC
Old Feb 25, 2003 | 12:15 PM
lonsal's Avatar
I've added an option to the TDS 202170 greasable rear sway bar bushing kit. If you order it and specify the size option "NB" you will get the kit less the sway bar bushings. $22 will automatically be deducted when you checkout. The kit would consist of 2 U-bolts, 2 saddles, 2-brackets (with grease fittings and covers, just remove them if you want) 2 washers and two nyloc insert nuts. The U-bolts, saddles and sway bar bushing brackets are yellow-zinc plated as always. If you already have polyurethane or poly-graphite bushings you could order this option and modify your own bushings to be greasable. You asked, now the option is available.
Lon Salgren
Top-Down Solutions
Old Feb 25, 2003 | 06:21 PM
ebmiller88's Avatar
Thanks Lon!!
I tell you guys, THIS is an fine example of service to the customer. I have his 36mm greasable bushings and sway bar brackets on the front of my Iroc and I couldn't be happier.
Ed
Old Mar 2, 2003 | 08:59 PM
IHI's Avatar
IHI
Hey Lon, Tom at House of Camero is fast as hell. WOW. He gave me a price, ended up crediting me casue shipping was a little less than expected-unusual, and I had them 2 days later. Very good guy to deal with for any of you that might need parts. Thanks for the lead.
Old Mar 2, 2003 | 10:13 PM
ebmiller88's Avatar
CamAro dammit....
LOL....Ed
Old Mar 2, 2003 | 10:42 PM
IHI's Avatar
IHI
damn, my bad-should be House of Wanna-be Firebird, lol
Old Mar 3, 2003 | 06:57 AM
JamesC's Avatar
Lon,
I received the kit a couple days ago. As usual, service and product are first rate.
JamesC
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
