Question about popping noise in front when braking
Old Mar 1, 2003 | 01:21 AM
gabebandit's Avatar
Hi everyone. I have a popping noise from the front of my Bird when braking. It does it as soon as the weight shifts forward. Anybody else experienced this? Thanks.
Old Mar 1, 2003 | 09:21 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Re: Question about popping noise in front when braking
Could be a few things, damaged FSB bushing, strut, caliper....
Old Mar 2, 2003 | 01:56 PM
breathment's Avatar
check your ball joints and make sure all the brake hardware bolts are tight first..
Old Mar 2, 2003 | 06:10 PM
sllt1776's Avatar
Car: 89 Iroc-Z
i agree with breathment. it's probably the ball joints if everything else is tight.
Old Mar 2, 2003 | 06:27 PM
gabebandit's Avatar
I already put in new ball joints. I think I'll try the calipers next. There old anyway.
Old Mar 2, 2003 | 06:34 PM
sllt1776's Avatar
Car: 89 Iroc-Z
if the bolts are tight on the calipers and the brakes are fine and not pulling to either side due to the caliper being stuck i think you would be wasting money. i would check the strut mount bearings or the a arm bushings. but that's just my opinion.
Old Mar 2, 2003 | 06:47 PM
gabebandit's Avatar
ITS PROBALLY THE STRUT PLATES. I'VE PRETTY MUCH REPLACED EVERYTHING ELSE.
Old Mar 2, 2003 | 06:48 PM
sllt1776's Avatar
Car: 89 Iroc-Z
spohn sell a set for a good price. i would also consider a wonder bar if you don't already have one
Old Mar 2, 2003 | 06:52 PM
gabebandit's Avatar
I'LL HAVE TO CHECK THEM OUT. I KNOW THAT GMHTP SAID THAT THEY COULD POP IF THEY WENT BAD. THANKS.
Old Mar 2, 2003 | 08:15 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
My car did that when it needed new front wheel bearings.
Old Mar 3, 2003 | 08:54 PM
breathment's Avatar
forgot to mention that.. very well could be
Old Mar 3, 2003 | 10:18 PM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
mine iroc did this when i got the car.. it ended up being the tranny mount. easy fix...
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
B_Dubya
Aug 26, 2015 05:09 PM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
