Relocation Brackets and saftey question
Old Mar 7, 2003 | 12:28 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Just a quick question, I bought spohn relocation brackets, probably going to install them this weekend or next when I go to put my 9" in. Will it be safe to only bolt them in until I can get to a shop to have them welded in?
Old Mar 7, 2003 | 12:43 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I wouldn't get on it or anything, but it should be safe for a couple miles. Don't quote me on that, I can't remember what they look like.
Also, did you get the ones for the 9" rear?
Old Mar 7, 2003 | 12:45 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
no, look at the design, it has one bolt holding it in. it could easily pivot.
just take it to the shop, you save no time by bolting it on before, all you have to do is undo 1 bolt. and replace 2 bolts. and then weld it, if you are paying shop rate, in fact, i would unbolt the LCA BEFORE welding it anyway, so you just asymbling it, to disassemble.
Old Mar 7, 2003 | 09:45 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I second that... Have them welded before the rear is in the car. You will be able to get the welder to it much easier. I welded mine while under the car, it would have been cleaner if the rear was out, use that to your advantage.
Old Mar 7, 2003 | 09:49 PM
Ions91Z28's Avatar
Hmmm, good point. I didn't even think about it that way.
Genopsyde
Nov 11, 2015 10:46 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
