I need a new posi unit
Old Mar 31, 2003 | 09:24 PM
Brian's87iroc-z's Avatar
hey, im new at this but i just wanted to know if anyone knows where i can get a new posi unit for a decent price, because my is almost shot. Everytime i peel out i only leave one tire mark. I was told to get a new posi unit. Is there anything else i can do to fix this or does anyone have any other ideas?
Old Mar 31, 2003 | 10:11 PM
2laneblacktop's Avatar
SLP sells a take-off unit that is practically brand new for $99. It is well worth it for the price.
Old Mar 31, 2003 | 10:39 PM
85_ZED28's Avatar
Car: '85 Z28
The SLP unit is only for 28 spline axles correct? Your car, being an '87 will require a 26 spline posi unit.
Old Mar 31, 2003 | 10:47 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
you could use the slp takeoff unit. however, you'd need 28 spline axles.
i think moser makes their axles in 28 spline. would be an improvement over the stockers...
Old Apr 2, 2003 | 08:47 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
First you need to make sure that you are not running a 9-bolt system. Then for $100 you can get the SLP posi. I would just get some 28 spline axles, they will last longer, are cheap, and will hold up a lot more power than those 26 splines.
Old Apr 2, 2003 | 10:22 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
You plan on keeping this car for awhile? and driving it rough like you said you do above? Then don't get a used takeoff SLP- get a quality Auburn posi or you will be paying for another unit + install in no time flat.
92projectcamaro
Dec 8, 2015 12:25 AM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
tattmann
Sep 27, 2015 05:20 PM
ironbmt
Sep 27, 2015 06:00 AM
