What size spacer between drum and z28 Rims on a 91
Old Apr 2, 2003 | 02:17 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
My GF got a 91 RS and got a set of 91 Z28 rims and I know we need some sort of small spacer between the rim and drum. What size is it? Thanks
Old Apr 2, 2003 | 02:26 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
matt:
i'm pretty sure they're 1/4 inch spacers.
Old Apr 2, 2003 | 02:33 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Yup, 1/4"
Old Apr 2, 2003 | 03:50 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
This is goona sound stupid.But whats the reason for the spacer
I dont have them on my 87 iroc.Do you need them?
Old Apr 2, 2003 | 03:55 PM
Omega's Avatar
Engine: LS1 / LS3
I have heard rumors about 2 reasons.
1) The spacer prohibited corrosion between the rim and drum, so they wouldn't rust together.
2) The drum brakes gave the rear 1/2" less total width over the disc setup. The spacer brought the rim out to the correct width.
Old Apr 2, 2003 | 03:58 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
can i just use 5 hardened steel 1/4 washers?
Old Apr 2, 2003 | 08:02 PM
Omega's Avatar
Engine: LS1 / LS3
Um, NO. You have to think about the contact area of the rim surface to the drum. If anything run the car without the spacers until you get a set.
If you are that bad off, I think I have a spare set that I will let for cheap. PM me if need be.
Old Apr 2, 2003 | 08:33 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
The spacer was installed on Iron drum brake cars to maintain the same distance when the Aluminum drums were discontinued. Not that big of deal if you decide not to use them. Most were lost over the years when cars changed hands.
Old Apr 2, 2003 | 10:15 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Oh... NP thanks lol I'm not cheap I'll run and get a set. Can I use a 1/4 universal 5 bolt set from Mr Gasket?
Old Apr 2, 2003 | 11:10 PM
Omega's Avatar
Engine: LS1 / LS3
The Mr. Gasket shims will work just fine.
Old Apr 3, 2003 | 09:22 AM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
1/4 huh? My spacers are pretty thin, about a 1/8 or 1/16 maybe. I kind of wondered why they bothered.
Old Apr 3, 2003 | 09:27 AM
DJP87Z28's Avatar
When I had mine they measured .187 or 3/16". I forgot to add in my previous post that they were also added to be used with the 16" wheel & tire package.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
